Dashboard display
Started by tunkmountainman, July 19, 2024, 08:39:08 PM
tunkmountainman
My Moteino Gateway dashboard is displaying old sensor values even with the node not powered -up. Also sensor dates and times from 2 years ago. Anybody else have the same issue?
sparky
While your waiting for others to respond I'll give you my take.  If I'm understanding your question correctly what your describing sounds normal.  The values your seeing is from the last time the node was connected to the gateway.  If your not using them nodes just delete or power them back up.
Those must be old node values so it's rather normal.
If you power up those same nodes new data will start coming in with new timestamps.
tunkmountainman
Thank you Felix you were correct I reinstalled the gateway and everything is baco normal. Thanks again.
