Custom node/metrics
Started by HeneryH, October 12, 2017, 08:42:31 PM
HeneryH
I just saw one reference earlier today but can't seem to remember what I searched for and can't find it now...
Can someone please post a help note on how to create a new node type with a new metric type?
I created an RFID Mot that reads the Unique ID off cards and sends to them to the GateWay Mot as a metric type RFID:xxxxxxxx where xxxxxxxx is a hex number.
What the server does when it gets that message remains an open question to be tackled after I first get the gateway to receive and recognize it.
HeneryH
Quote from: sparky on October 12, 2017, 09:26:48 PM
Was it this post;
https://lowpowerlab.com/forum/projects/rfid-moteino-controled-access-system-(finished)/msg2801/#msg2801
No, it was something from Felix saying that Metrics are of of the form "Metric:Value" and that the Metric has to be added to some config file on the gateway so that it is defined and recognized.
I'm hoping there is another edit to create a new type of node in addition to the new type of metric.
kni
This is not the thread(droid) you are looking for, but have you read the help text in the source code?
https://github.com/LowPowerLab/RaspberryPi-Gateway/blob/master/metrics.js#L22
Reminds me that creating a new metric is on my to-do list as well.
HeneryH
#4
Awesome, thanks.
The following may seem specific to the application I am working but the concepts remain valid for any new Mot that someone wants to create so I hope you don't mind me proceeding with the discussion...
So for RFID Reader that is sending across the following string showing the Unique ID (UID) of the presented card:
RFID UID:5007de16
If I put a metric.js line like
RFID_UID: { name:'UID', regexp:/UID\:([0-9a-fA-F]+)/i, value:'', unit:'', },
Then the gateway should register the receipt of the RFID tag.  The data is not numeric in the sense of temperature of similar so not much can be displayed except maybe the log of the event.
Maybe create a Mot type for the RFID Reader with nothing special for settings.
  RFIDMote: {
    label  : 'RFID Sensor',
    icon   : 'icon_sonar.png',   <-- create one
    settings: { lowVoltageValue: '' }, //blank will make it inherit from global settings.json lowVoltageValue, a specific value overrides the general setting, user can always choose his own setting in the UI
Maybe further investigation of this file will be able to react to the presented ID and reply back to the gate lock with an 'open' command of some type.
HeneryH,
Your metric has to be numeric, or else you have to assign a static value to each incoming non-numeric value, to be saved as the actual value.
Look at the GARAGE metics for instance, or the SwitchMote ones. Each incoming word value (OPENING, OPEN etc) has a numeric value assigned to be saved /logged.
THe easiest is to send that value in decimal values which can be extracted directly. I don't think hex will work.
BUT you can use the valuation() function to extract your value and manipulate however you want, and then return a value based on it.
For instance the FH metric:
FH : { name:'F', regexp:/\bF\:(-?\d+)\b/i, value:'', duplicateInterval:3600, valuation:function(value) {return value/100;}, unit:'°', pin:1, graph:1, graphValSuffix:'F', graphOptions:{ legendLbl:'Temperature', lines: { lineWidth:1 }}}
Here the node sends the temperature without decimal point, so it needs to be divided by 100 to get the actual value. This is a simple example that illustrates how you would manipulate a value.
For a hex (as defined by your regex), you would get the matched value as a string, then you can use javascript to extract the number you need from it.
I hope this helps.
HeneryH
Thanks for the clarification Felix.  I can just turn it into the numeric equivalent of the hex.  The cards I am using are only eight characters.
HeneryH
#7
Felix,
   Do does the evaluation of the reg expressions go in order and kick out if one hits?  Or maybe alternatively, go through them all and the last one standing wins?
exports.metrics = {
  RFID_UID : { name:'UID', regexp:/UID:xxxx/i, value:'Card 01'},
  RFID_UID : { name:'UID', regexp:/UID:yyyy/i, value:'Card 02'},
  RFID_UID : { name:'UID', regexp:/UID:xxxx/i, value:'Card 03'},
  RFID_UID : { name:'UID', regexp:/UID:[0-9a-fA-F]+/i, value:'Unknown Card'},
Or more simply
exports.metrics = {
  RFID_UID : { name:'UID', regexp:/UID:xxxx/i, value:'Known Card'},
  RFID_UID : { name:'UID', regexp:/UID:yyyy/i, value:'Known Card'},
Where xxxx, yyyy and zzzz are the known UIDs and if non of those hit then it will get set to "Unknown"?
Paired with
exports.events = {
  RFIDAlert : { label:'RFID : Card Detected', icon:'audio', descr:'Alert sound when RFID Card is detected',
                                                if (node.metrics['UID'] && (
                                                           node.metrics['UID'].value == 'Card 01' ||
                                                           node.metrics['UID'].value == 'Card 02' ||
                                                           node.metrics['UID'].value == 'Card 03' ||
                                                           node.metrics['UID'].value == 'Card 04'
                                                      io.sockets.emit('PLAYSOUND', 'sounds/access_granted.wav');
                                                } else {
                                                      io.sockets.emit('PLAYSOUND', 'sounds/access_denied.wav');
                                               };                  <-- what is with this semicolon?
Your metrics are not conforming to the expected metric:value format, you only have a value.
First match wins.
HeneryH
How about the correction above?
Thats better but you have to also assign a numeric logValue if the value is not numeric.
See these samples, notice the logValue 0 and 1:
closed : { name:'Status', regexp:/(?:STS\:)?(CLS|CLOSED)/i, value:'CLOSED', pin:1, graphValPrefix:' Door: ', graph:1, logValue:0 },
open : { name:'Status', regexp:/(?:STS\:)?(OPN|OPEN)\b/i, value:'OPEN', pin:1, graph:1, logValue:2 },
HeneryH
#11
Awesome, I will be testing this out tonight.
exports.metrics = {
  RFID_UID : { name:'UID', regexp:/UID:xxxx/i, value:'Card 01', logValue:1},
  RFID_UID : { name:'UID', regexp:/UID:yyyy/i, value:'Card 02', logValue:2},
  RFID_UID : { name:'UID', regexp:/UID:xxxx/i, value:'Card 03', logValue:3},
  RFID_UID : { name:'UID', regexp:/UID:[0-9a-fA-F]+/i, value:'Unknown Card', logValue:0},
//example of overriding an event
exports.events = {
                                                } else {
exports.motes = {
  RFIDMote: {
You forgot your correction  ;)
regexp:/UID:xxxx/i
HeneryH
Quote from: Felix on October 13, 2017, 01:30:50 PM
regexp:/UID:xxxx/i
Too many edit buffers open  :)  Got it.
HeneryH
#14
The following code is not executing as expected.  Can anyone spot the error?
If I set the hardcoded  "  || 1"  to force the expression to be true, then the doorbell sound rings.
If I set the hardcoded  "  || 0" to have the evaluator check the UID of the card, it does not work.
The gateway is receiving the following message from the RFID Mot
[10-14-17_17:58:18.724] [LOG]   >: [22] RFID UID:90a3e116 BAT:0.98v   [RSSI:-49][ACK-sent]
[10-14-17_17:58:18.826] [LOG]   post: /home/pi/gateway/data/db/0022_V.bin[1508003898,0.98]
[10-14-17_17:58:18.852] [LOG]   post: /home/pi/gateway/data/db/0022_RSSI.bin[1508003898,-49]
[10-14-17_17:58:19.008] [LOG]      [22] DB-Updates:1
So the gateway is getting the UID of 90a3e116 as expected.
The metric file should be getting that and mapping the value to "Card 01" then evaluating the event to ring the doorbell when there is a match for Card 01.
exports.metrics = {
  RFID_UID : { name:'UID', regexp:/UID:90a3e116/i, value:'Card 01', logValue:1},
  RFID_UID : { name:'UID', regexp:/UID:8008e616/i, value:'Card 02', logValue:2},
  RFID_UID : { name:'UID', regexp:/UID:[0-9a-fA-F]+/i, value:"Unknown Card", logValue:0},
exports.events = {
  rfidSound : { label:'RFID : Xxx ', icon:'audio', descr:'Play either grant or denysound when RFID card is detected', serverExecute:function(node) { if (node.metrics['UID'] && (node.metrics['UID'].value == 'Card 01' || 0 )) { io.sockets.emit('PLAYSOUND', 'sounds/doorbell.wav'); }; } },
So the either the mapping of the value to "Card 01" is not happening or the evaluation of node.metrics['UID'].value == 'Card 01'  is not triggering as TRUE.
I was thinking that maybe the string compare wasn't behaving properly with strings so I tried switching to strcmp(a,b) but that syntax wasn't accepted.  I tried double-quotes instead of single quotes without success.  I'm not 100% on the syntax being used here so if there is any advice I would greatly appreciate it.
