Change http ports
Started by kwalkerk, September 23, 2018, 01:22:35 PM
kwalkerk
I'm already running a web service on port 80 on my PI.  After installing the Pi
Gateway, the startup script for that service gives the message that port 80 is already in use.  Can I change the default ports for the PiGateway?  If so where?
kwalkerk
I finally found it.
The nginx ports are defined in /etc/nginx/sites-enabled/default.
Made the change there an now everything works again.
Good find, thanks for the follow up ;)
