Hello, all
i learned a lot from Felix's lowpowerlab, and thanks a lot for his alsome project.
i try to use chinese chip which can totally replace ATMEGA328P, and made a new pcb. Works well .
By the way, the new chip is call LGT8F328P
Is it any good over wider temp range?
Not the temp. but the improvement for others,here is the list:
from what I have seen, it doesn't switch pin states faster than 328 @ 8MHz output on pin, slower slew rate
I like how it has full Arduino Support while the UNO/328p has only Partial ;D
This is china's chance to impress us :D
How about low power? I'm very curious in that department.
Hi, Felix
This chip is totally new design, and own bootloader. For the power, it has two level: DPS1 7uA and DPS2 1uA.
Here's a review by an avrFreaks user (original post here (https://www.avrfreaks.net/forum/forbiden-tech-china-has-arrived?page=all)):
QuoteThat's right, I ordered a board with the infamous AVR clones from Logic Green. It's an Ocrobot Alpha with the LGT8F328P MCU. The board itself is pretty crappy, no crystal, uses an internal 32MHz oscillator divided by 2 (16MHz).
So it's kind of an Arduino clone, comes with the optiboot bootloader. But is this MCU a piece of crap, or should Microchip be worried and start preemptive lawsuits? I will test it and find out.
The markings on the MCU have been erased, but I did a memory dump (the flash is mapped as a RAM address, like the new Tiny models) and it checks out.
(https://www.avrfreaks.net/sites/default/files/ocrobot_alpha.jpg)
