Similar to this observation here:
https://lowpowerlab.com/forum/general-topics/rfm69-with-bean-very-slow-1-5-seconds-to-do-simple-send()-probably-config/msg19597/?topicseen#msg19597
I first tested out two moteinos (433Mhz, RFM69HCW) and tested out the Gateway/Node and it works fine.
I then created the Arduino+RFM69HCW in the configuration (with a logic level shifter):
https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide?status=7
When I upload and run the Node code on the Arduino, it seems to "work" but runs very slowly. The Arduino code returns the "nothing..." but around every 3 seconds, while the moteinos were giving " ok!" every ~200ms. It seems to be hanging up in the sendWithRetry for some reason. Am I missing something?
The antenna is pretty important, can you post a photo of your setup and antenna?
The arduino are not very far apart on my desk, and the antennas are about 2.5 inch? Would I have to look in the library to change something for the Arduino hardware? I might try soldering up another RFM69HCW, just to see if it was that.
If that's a monopole antenna, try soldering an equally long wire perpendicular to it, away from the board.
Otherwise it's too hard to tell what's going on there, lots of wiring.
Is it getting stuck in canSend() then timing out after a second? Is it the readRSSI() routine not dynamically reading RSSI properly?
