I plan to use you moteino with the wireless flash functionality.
But the memory "W25X40CLSNIG-ND" is not available in germany and to order it from somewhere else is ridiculous expensive.
Do you know any similar one?
I found "SRAM 23K256-I/SN SOIC-8N Microchip Technology", it has the same footprint, but I do not know if it will run with your c library.
<http://www.produktinfo.conrad.com/datenblaetter/650000-674999/651216-da-01-en-SRAM_23K256_I_SN_SOIC_8N_MCP.pdf>
Quote from: ulli on July 19, 2015, 02:41:15 PM
No, Ulli, that won't work. That is an SRAM, not a flash ROM. If you'd like I'll try to take a look at what's available, what suppliers do you use (links would be helpful).
Digikey in Germany has that memory in stock for 0.33 Euro in single piece qty. Their PN is: W25X40CLSNIG-ND
http://www.digikey.de/product-detail/en/W25X40CLSNIG/W25X40CLSNIG-ND/3008652
I prefer buerklin.de and sometimes I need to use conrad.de.
The issue on digikey is, they charge 18€ for shipping and that's not acceptable for a 33cent product.
