Okay I'm back at it with a new C++ book for Dummies. I have code that gets temperature from ds18b20 converts it to F and sends over the radio to the gateway successfully at a regular interval. Thats good but I'd like to send only IF the temperature changes and IF it remains steady to then send at a regular scheduled interval. So here is the relavant parts of code and I can't seem to make it work. Please help. :)
//############# Begin code for temperature #########################
sensors.requestTemperatures();
float s4 = sensors.getTempC(watertemp);
if (s4 > 0)
double ptemp; // declare as double
float ctemp = sensors.getTempC(watertemp); // get temp in C
ptemp = (ctemp * (9.0 / 5.0) + 32); // convert temp C to F
dtostrf(ptemp, 3, 2, pipetemp); // convert float to String
else
Serial.println("Debug, you only see this if sensor not working!");
//############# End code for temperature #########################
// #####################send over radio part #####################
if (timer2 > interval2)
timer2 -= interval2; //reset the timer
// byte buffLen=sprintf(buff, "node%d:%s", NODEID, pipetemp);
byte buffLen=sprintf(buff, "node%d/temperature/%s", NODEID, pipetemp);
if (radio.sendWithRetry(GATEWAYID, buff, buffLen));
//######## End send over radio ########################
//##### My attempt to send or in this case test over the serial print ######
// test area
if (pipetempState != pipetemp) {
// Print over radio if temperature changes
Serial.print(pipetemp);
Serial.println(" this is the pipetemp var");
Serial.print(pipetempState);
Serial.println(" this is the pipetempState var");
Serial.print(" if you keep seeing this it didnt work");
pipetempState=(pipetemp);
else
Serial.println(pipetemp);
Serial.print(" if you see this only on temp movement");
//pipetempState=(pipetemp);
//end test area
I think this si going to work. Now I just have to add radio portion of code.
// new test area #######################################
if (strcmp(pipetempState, pipetemp) == 0) // test to see if the two strings are equal
Serial.println(" ######");
Serial.println("Equal");
Serial.println(pipetempState);
else
Serial.println("NotEqual");
strcpy(pipetempState, pipetemp);
