Hardware support => Moteino => Topic started by: HeneryH on September 24, 2017, 10:42:35 AM
Title: Really basic question... Should Blinky work?
Post by: HeneryH on September 24, 2017, 10:42:35 AM
I'm trying some custom code and first shot didn't work so I am starting with the very basic tutorials and working up.
The Blinky tutorial should blink the built-in LED on pin 13.  I see on the schematic that the Moteino seems to have an LED on 13.
So...   If I connect a Moteino to the FTDI adapter and successfully upload the Blinky sketch, shouldn't the on-board LED start blinking?
I'm using the Arduino/Genuino Uno board type.
  Blink
  Turns an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
  the correct LED pin independent of which board is used.
  If you want to know what pin the on-board LED is connected to on your Arduino
  model, check the Technical Specs of your board at:
  https://www.arduino.cc/en/Main/Products
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
  modified 8 Sep 2016
  by Colby Newman
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/Blink
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
Title: Re: Really basic question... Should Blinky work?
Post by: ssmall on September 24, 2017, 07:38:26 PM
Led is on digital pin 9 for a Moteino:
https://lowpowerlab.com/guide/moteino/out-of-box/ (https://lowpowerlab.com/guide/moteino/out-of-box/)
Post by: syrinxtech on September 24, 2017, 10:00:37 PM
As ssmall said, the Moteino uses D9 for the built-in LED.  The Arduino uses D13.
And, for best results, you should probably add the Moteino family of devices to your Arduino IDE.  This is particularly true if you ever want to add a Mega Moteino or some of the other Moteino products.
There are directions on the Felix's web site showing how to add the Moteino device type to the IDE.
Post by: HeneryH on September 24, 2017, 10:37:22 PM
Sorry, don't know how I missed that.   Thanks.
