Hello everybody,
i need your help on a problem i can't solve :/
I have two things on SPI (the RFM69HW and my audio player : VS1053B)
here the main code i use :
void loop()
if(digitalRead(tilt)==LOW)
val=random(1,5);
sendData(val);
// str=String(val);
//Serial.println(val);
//str.toCharArray(morceau,8);
sprintf(morceau,"%d",val);
if(val>99){
morceau[3]='.';
morceau[4]='m';
morceau[5]='p';
morceau[6]='3';
morceau[7]='\0';
if(val>9 && val<100){
morceau[2]='.';
morceau[3]='m';
morceau[4]='p';
morceau[5]='3';
morceau[6]='\0';
if(val<10){
morceau[1]='.';
morceau[2]='m';
morceau[3]='p';
morceau[4]='3';
morceau[5]='\0';
Serial.println(morceau);
// if(musicPlayer.stopped())
Serial.println("debut local");
musicPlayer.setVolume(volume,volume);
musicPlayer.playFullFile(morceau); // ou startplayingfile a tester
Serial.println("fin local");
temps = millis();
while((millis() - temps) < tempsAction)
//Serial.println(millis());
getAcc();
else
receiveData();
I don't understand why when my program is running a music flle (musicPlayer.playFullFile(morceau), the program dont leave the fonction until the end of the file) and when the gateway send to it a data the music stopped and the moteino stop working
The usage i try is :
IF boutton HIGH
Playfile number XX
Send to gateway XX
wait or do something during a specific time
ELSE
listen if gateway send something
Hope you will have an idea because i try everything ....
thanks a lot for your help
(again sorry about my english ;)
WHat hardware do you use and how do you have the devices wired?
I use a moteino with the RF69HW (spi) and the vs1053b plugged like the tutorial (simple wiring spi https://learn.adafruit.com/downloads/pdf/adafruit-vs1053-mp3-aac-ogg-midi-wav-play-and-record-codec-tutorial.pdf )
Use another CS for your adafruit board. Used and available pins are shown here: https://lowpowerlab.com/moteino/#pinout
It looks like the music board requires 5V for power. Moteino is a 3.3V device so you must use buffering if the music board sends 5V signals to the Moteino.
I already used an other pin because it was not working with the same pin.
I used 5V power and not 3.3V from moteino.
the problem come when my moteino is playingfullfile it receive a data from radio.
maybe the RF69HW stop the spi connection beetween the VS1053 and the moteino because it receive something...
Do you have a idea how to shut down the radio module or sleep or anything else and wake up after to be sur it's not that.... ???
You will need to check how the audio board library does the SPI communications. The RFM69 uses "SPI transactions". Perhaps there is a conflict on the SPI bus.
Hello Felix,
thanks for taking time for me :)
I have search about "spi transactions" in my audio library and datasheet (https://www.sparkfun.com/datasheets/Components/SMD/vs1053.pdf) and i found nothing :/
I try a lot of other thing in my code like : sent a flag to my moteino gateway to avoid it send to a moteino which is playing but it's not working...
Is that possible to sleep the radio module or shutdown it .. ????? and wake up after ?
thanks again
Yeah: radio.sleep()
Wake it up by calling radio.receiveDone()
I think thats work ;) i have to test more because i have to leave soon today.
I will tell you ;) thanks again
