I've plans to control my sliding gates with Moteino and I was wondering if I can use one of the power outputs from sliding gates motorgear (Beninca Bull 8 (https://www.beninca.com/au/automations-for-sliding-gates/bull-/max-gate-weight?v=800+Kg), see schematics HERE (https://benincauk.co.uk/wp-content/uploads/CPBull_8OM.pdf), 1st page).
There are two 24Vac/0.5A outputs, which are used for photocells and 12V outputs.
Description of the outputs:
• +12V COMMON - Common for control inputs.
• 24Vac - Output, power supply of accessories, 24Vac/500mA max
• COM (+12V) - Common for limit switches.
• 12-0-12 Secondary - Connection of secondary winding of 24V transformer
Can I wire some kind of AC to DC converter to one of these outputs and power Moteino with it?
If yes, which ac-dc converter do you suggest?
Diode rectifier (any general purpose diode) + capacitor smoothes out the AC, then feed it into a DC-DC converter to bring it down to "nice" inputs for the Moteino LDO.
