Hi i am new to arduino/moteino and i have a problem with power consumption.
Mission: make a shock-sensor with moteino, able to send a massage to a receiver.
My hardware setup is as follows: moteino RFM69HW w. flash hooked up with a shock sensor ( connected to D3 and GND).
the problem is that if i run the code with RFM69HW commented out in line 55 and 80 it works perfectly, with a very little power consumption 0,03mA, BUT if i uncomment RFM69HW in line 55 and 80 the hole thing stops working and jumps to a power consumption of approx. 110mA constant.
The code i am using is the one attached.
best regards
ABL
It's easiest to look at code if you paste it into a 'code' block - you see a little button above the input field with a '#' symbol. Use that and then paste your code between the
'[ code ][ /code ]' blocks.
Also, it would help if you describe what a 'shock sensor' is (part number, reference to datasheet, etc.).
Ok thank you Tom :)
The shock sensor/vibration sensor is this one https://www.elfa.se/elfa3~eu_en/elfa/init.do?item=73-026-23&toc=0
and the code
#include <RFM69.h> //get it here: https://www.github.com/lowpowerlab/rfm69
#include <SPI.h>
#include <LowPower.h> //get library from: https://github.com/lowpowerlab/lowpower
//writeup here: http://www.rocketscream.com/blog/2011/07/04/lightweight-low-power-arduino-library/
// *********** IMPORTANT SETTINGS - YOU MUST CHANGE/ONFIGURE TO FIT YOUR HARDWARE *************
#define NODEID 2 //unique for each node on same network
#define GATEWAYID 1
//#define FREQUENCY RF69_433MHZ
//#define FREQUENCY RF69_868MHZ
#define FREQUENCY RF69_915MHZ
#define ENCRYPTKEY "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
#define IS_RFM69HW //uncomment only for RFM69HW! Remove/comment if you have RFM69W! --------- DET VIRKER PERFEKT, SÅ LÆNGE JEG KOMMENTERER DENNE LINIE UD, ALTSÅ SÆTTER DEN TIL RFM69W
#define ACK_TIME 30 // max # of ms to wait for an ack
#define MOTIONPIN 1 //hardware interrupt 1 (D3)
//#define SERIAL_EN //comment this out when deploying to an installed SM to save a few KB of sketch size
#define SERIAL_BAUD 115200
#ifdef SERIAL_EN
#define DEBUG(input) {Serial.print(input); delay(1);}
#define DEBUGln(input) {Serial.println(input); delay(1);}
#else
#define DEBUG(input);
#define DEBUGln(input);
RFM69 radio;
volatile boolean motionDetected = false;
char sendBuf[32];
byte sendLen;
Serial.begin(SERIAL_BAUD);
#ifdef IS_RFM69HW
radio.encrypt(ENCRYPTKEY);
pinMode(MOTIONPIN, INPUT);
attachInterrupt(MOTIONPIN, motionIRQ, FALLING);
char buff[50];
sprintf(buff, "\nTransmitting at %d Mhz...", FREQUENCY == RF69_433MHZ ? 433 : FREQUENCY == RF69_868MHZ ? 868 : 915);
DEBUGln(buff);
int detectedNumber = 0;
const int detectedRequired = 3;
void motionIRQ()
detectedNumber++;
motionDetected = true;
void loop()
if (motionDetected = true && (detectedNumber == detectedRequired)); //
detectedNumber = 0; //reset "counter"
sprintf(sendBuf, "HI");
sendLen = strlen(sendBuf);
if (radio.sendWithRetry(GATEWAYID, sendBuf, sendLen));
DEBUG("HI ACK:OK! RSSI:");
DEBUG(radio.RSSI);
radio.sleep();
motionDetected = false; //do NOT move this after the SLEEP line below or motion will never be detected
Ok so assuming your sensor is low power and produces a HIGH on D3 you can pick that up with the MotionMote sketch which looks like your code is already trying to do.
If you got a HW then you definitely need to uncomment IS_RFM69HW. It's really important you are sure what the radio is : W or HW and use code accordingly.
hi :)
it should be a HW, but can i see if it is or not?
the sensor is low power, but it produces a LOW on D3, i have used the motionMOTE sketch but the result is the same. as soon as i uncomment RFM69HW it f.... up. if i comment RFM69HW it works perfectly..
if i load the gateway and node sketch and set it to RFM69HW it works perfectly, and I have several hundred meter range.
but as soon as i use RFM69HW in the motionMOTE sketch it dosn't work.
Do you have your invoice?
If you post a photo of your Moteino underside I can tell you.
i bought it at digitalmeans.co.uk, but yes i doit says moteino+RFM69HW+flash -868/915mhz(R4)
pic. attached
regards anders
Yes this is definitely a RFM69 HW.
You need to call radio.setHighPower(), or uncomment IS_RFM69HW.
I would advise taking back 1 step and load a stock Node-Gateway setup (adjust settings and HW etc). Make sure the node is functional and then go back to the Motion sketch. I assume your gateway is another Moteino? Any details on that?
ok i will try that, thanks :)
yes it is, i should be the same.. se pic.
Ok that is also a HW.
Please try the Gateway and Node sketches in the examples (https://github.com/LowPowerLab/RFM69/tree/master/Examples), to ensure you have a good starting point.
Hi Felix
The gateway and node sketches works perfectly fine.
regards
anders
Ok so we know the hardware is functional.
yes the hardware is functional, it's the code causing the problems, the strange thing is that the motionMOTE sketch is causing the exact same problem as the code i posted earlier...and it should work
Quote from: ABL on May 28, 2015, 01:45:10 PM
Hi Felix
regards
anders
Does the 'Node' sleep in the example Sketch? And, if so, did you measure the current drawn?
Quote from: ABL on May 28, 2015, 01:43:12 AM
Ok thank you Tom :)
and the code
#include <SPI.h>
#define GATEWAYID 1
#ifdef SERIAL_EN
#else
RFM69 radio;
char sendBuf[32];
byte sendLen;
#ifdef IS_RFM69HW
char buff[50];
DEBUGln(buff);
void motionIRQ()
detectedNumber++;
void loop()
DEBUG(radio.RSSI);
radio.sleep();
Looking at this code, I wonder if you're still moving (AKA getting Pin Interrupts) while you are trying to go to sleep. If so, you may need to delay sleeping until you are sure the shock sensor is quiescent before you try to sleep - otherwise the system may stay in a high powered state. You should be able to sleep the radio during the delay (just make sure that you lock out any further reporting until the delay is over) and that should save a significant amount of power.
Quote from: ABL on May 28, 2015, 04:31:29 PM
How can you verify that without using an actual PIR motion sensor?
The sketch was not coded for a shock sensor specifically but for a motion PIR sensor which creates 1 HIGH pulse every few seconds if there's movement, so we only made assumptions here about your sensor. Don't expect the sketch to work if you just load it on your Moteino and then play with it in your hand. Static will cause D3 to go HIGH and create interrupts. You need a real PIR sensor to have it work properly. I don't know how your shock sensor works in reality, what the output is and how it responds to shocks. It may require different code to have it work as expected.
Hi Felix & Tom
i have tried to change the code, and this seems to work, except from detachInterrupt(MOTIONPIN) i don't know if i should use a different command.. see line 3 in the void motionIRQ)
#define GATEWAYID 1
#ifdef SERIAL_EN
#else
RFM69 radio;
char sendBuf[32];
byte sendLen;
void setup()
#ifdef IS_RFM69HW
char buff[50];
DEBUGln(buff);
volatile int detectedNumber = 0;
void motionIRQ()
//Disable interrupt here!!!!
detachInterrupt(MOTIONPIN);
detectedNumber++;
//------------for debugging-------
String s = "Motion detected, number: ";
String message = s + detectedNumber;
Serial.println(message);
//delay(5000);
void loop()
Serial.println("Loop entered");
if (motionDetected == true && (detectedNumber >= detectedRequired))
//------------for debugging---------
Serial.println("Motion - Do stuff");
//Radio stuff--------
//Serial.println("Radio - sending begin");
DEBUG(radio.RSSI);
//Serial.println("Radio - sending done");
//Serial.print("Radio sleep");
radio.sleep();
Serial.println("motionDetected set to false");
Serial.println("Enable interrupt");
Serial.println("Power down");
delay(100);
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
Anders, I wouldn't bother using 'detachInterrupt()' if all you want to do is temporarily disable that specific interrupt. I suggest that you research "interrupt masking on AVR". You should be able to simply mask the interrupts while you wait for the pin to quiesce and then re-enable just before you sleep (once the pin is quiet, of course). Also think about how you might code a simple filter to effectively 'debounce' the signal (hint: use 'debounce' as a keyword).
If you need help with this I might be able to post a snippet of code later today, but you should be able to find something on the web.
Hi Tom :)
That is exactly what i want to do.. I have tried to find something useful about interrupt masking on AVR.. i find something about sei() and cli() but i don't know if that is what you had in mind.. if this is correct, how do i call these commands.. do i need avr/interrupts.h, and if so do you where to download it..?
I have tried to debounce to, but with no luck, so if you can post a snippet of code, it would be great.
Anders
Ok, I'll post a snippet sometime my tomorrow morning (East Coast US)...
Quote from: TomWS on May 30, 2015, 02:17:29 PM
Well I'm afraid I got carried away...
As promised, here is the code snippet to simply enable or disable the INT1 interrupt (leaving the other interrupts enabled). Interestingly, the attachInterrupt and detachInterrupt functions are pretty efficient, but the macros below are very direct and allow you switch the interrupt on and off without affecting the other parts of your setup... (note that this doesn't work on all AVR processors, but does on Moteino processor)
#define MOTIONINT 1 // hardware interrupt 1 (D3) NOTE that this is DIFFERENT from PIN NUMBER!!!
// to understand following code, see: C:\Arduino\hardware\arduino\avr\cores\arduino\WInterrupts.c
#define enableShockInt { EIMSK |= (1<<MOTIONINT); } // need to set int mask bit to one, hence OR with mask
#define disableShockInt { EIMSK &= ~(1<<MOTIONINT); } // need to set int mask bit to zero, hence AND with complement of mask
Now, as to getting 'carried away', I realized that even 'debounce' doesn't give you exactly what you want so I, uh, rewrote your code... It's attached below and uses a function shockIntegrator() which integrates the shock sensor pulses based on a fixed sample interval and says motion is detected when a certain threshold has passed and says that it's ok to sleep after there is no motion for a certain number of samples. The integrator is controlled by the following constants:
#define SHOCK_SAMPLE_TIME 50 // number of milliseconds between integrating samples
#define SHOCK_THRESHOLD 10 // number of accumulated pulses to trigger radio send
#define SHOCK_ZERO_THRESHOLD 20 // number of sequential samples with no motion (20 * 50mS = 1second)
You can play around with these three constants to control when motion is detected and how long before you go to sleep.
I've attached the whole sketch in a zip file as it was too big to include here, but here is the snippet of the integrator:
// shockIntegrator() - filters the interrupts
// so that a certain number fall at a sufficiently high rate,
// and also detects when its quiet enough to sleep
int shockIntegrator(void)
static int // these variables need to be static to keep around between calls
integral=0,
numZeros=0;
uint32_t // general timer variables
now,
diff;
static uint32_t // this one needs to be static to keep it around between calls.
last=0;
int
rc=0; // assume nothing to report
now = millis(); // get current timestamp
diff = now-last; // calculate difference from last time to make rollover immune
if (diff > SHOCK_SAMPLE_TIME) // only check results at fixed intervals
last = now; // reset time
disableShockInt; // disable the interrupt while we process the count
if (detectedNumber) // did we get any interrupts inside of this window?
integral += detectedNumber; // yes accumulate them
detectedNumber=0; // reset the counter
// DEBUG - ok to do here since it's outside of interrupt handler and we've only masked OUR interrupt
message = s + integral;
DEBUGln(message);
} else
integral -= 1; // nothing this trip, bleed off the accumulated amount
enableShockInt; // re-enable the interrupts
if (integral >= SHOCK_THRESHOLD)
rc = 1; // say that we've exceeded the count
integral = SHOCK_THRESHOLD; // saturate at this high value
} else
if (integral <= 0)
integral = 0; // 'saturate' at zero
numZeros++;
if (numZeros >= SHOCK_ZERO_THRESHOLD) // have we had enough sequential zeros to sleep?
rc=-1; // yup, tell the caller...
numZeros = SHOCK_ZERO_THRESHOLD; // saturate value
return rc;
I've compiled the sketch just to make sure it builds but obviously did not attempt to test it...
Enjoy, let me know if you have any questions,
Hi Tom :)
Sorry for the late reply, I have been away because of work .
that is just awesome , i have just had a quick try with the full sketch and it seems to work perfectly :-)
just to be able to understand the whole interrupt concept, where can i read about it.... i can see you put something in the code snippet ..:
but it seems to be a path to your C drive, can you point me in the right direction...
Thank you for your help, i really appreciate it :)
best regards
anders
Quote from: ABL on June 09, 2015, 03:52:08 PM
Hi Tom :)
best regards
anders
Anders, the path:
C:\Arduino...is where your Arduino IDE is installed. Look on your system and see if you can determine where the IDE is installed and, once you've found it, then you can follow the rest of the path to look at this file, which is installed with the IDE.
TomWS - I am wondering if you'd be willing to assist on the "ShockTest" code included above.
I know I am reviving a 2 year old thread. If this is bad form, please let me know and I'll start a new topic.
Quote from: JonM on May 02, 2017, 08:15:31 PM
I'd suggest starting a new thread and asking the question you really want answered. I'm not sure I could help but there are plenty of others around here who are willing to help a specific question.
