Hardware support => Moteino => Topic started by: Naarlack on June 18, 2015, 04:02:21 AM
Title: Node to Gateway communication method
Post by: Naarlack on June 18, 2015, 04:02:21 AM
Hi guys,
I'm hoping somebody can explain what is the best method for communication between multiple nodes and the gateway. For the sake of an example, lets say I have 3 nodes that are powered from 9V batteries (which I'd like to make last as long as possible) and one gateway that is powered via USB. I'd like to grab the temperature from each of the 3 nodes approximately every 5 minutes for logging.
I can think of a few ways to do this:
And there are probably many other alternatives.
Is there a standard method that is best practice for use with Moteinos?
Title: Re: Node to Gateway communication method
Post by: Felix on June 18, 2015, 08:30:40 AM
You can do it in many different ways. The easiest is to sleep the nodes for X amount of time, then wake - read sensors - send data - go back to sleep. That's it. The standard is dictated by your requirements.
Post by: TomWS on June 18, 2015, 08:46:51 AM
Quote from: Naarlack on June 18, 2015, 04:02:21 AM
<snip> I have 3 nodes that are powered from 9V batteries (which I'd like to make last as long as possible)
If you want batteries to 'last as long as possible', don't use 9V batteries (unless your node needs >3.3volts for a peripheral).  For a primary battery use two Lithium AA or AAA cells.  The 9V battery is rated at approximately 565mAH and almost 2/3s of that power is thrown away converting down to 3.3V.  Use two Lithium AAA will give you 1200mAH @ ~3.5V without any conversion loss in about the same volume. (This is just a Thumbnail summary, the details are covered fairly comprehensively elsewhere in the forum)
  • <snip>
  • <snip>
  • <snip>
Yes, for example: Let the nodes sleep except when they collect and report data every five minutes.  The gateway collates all the data and reports it when the 3 node has reported in... as discusses in several places throughout the forum.
