Hardware support => Moteino => Topic started by: curious on July 10, 2017, 12:10:08 PM
Title: Moteino Resonator/Speed/Frequency?
Post by: curious on July 10, 2017, 12:10:08 PM
I've read that the Moteino uses a 16MHz ceramic resonator. I've also read that the "divide by 8" fuse is not set for the clock.
Hence I assume that Moteinos are running @16MHz?
But they use 3.3V, don't they?
How does 3.3V match 16MHz? According to the Atmega Datasheet for 16MHz the voltage would need to be higher...
Title: Re: Moteino Resonator/Speed/Frequency?
Post by: Felix on July 10, 2017, 12:48:08 PM
Yes 16mhz.
The reasons and justification are discussed in the forum many times before.
Post by: curious on July 10, 2017, 12:53:54 PM
Alright, did a search now and found https://lowpowerlab.com/forum/moteino/moteino-16mhz-3-3v-why/msg7612/#msg7612
That answers my question. I just wanted to know if the specs are up-to-date. Sorry for not searching before ;)
