Hardware support => Moteino => Topic started by: luisgcu on October 02, 2020, 10:40:12 PM
Title: Moteino pcb trace antenna
Post by: luisgcu on October 02, 2020, 10:40:12 PM
Hello all,
I am back again after several years absent of    this forum where I learned a lot and first shared my experiences with LoRa and moteinos.
This time I am working in LoRa project where one of the Lora node basically will be located at  someone pocket or purse.
I read that the trace antenna is ideal for such project ,  desired range  0.5-0.8 miles but. I just making test comparing pcb trace vs coil antenna.
I would like to know how the capacitor and resistor the pcb trace antenna termination was choose ?  I found some documents  on the web and resistor  value indicated is 2k .
Title: Re: Moteino pcb trace antenna
Post by: luisgcu on October 03, 2020, 07:47:19 PM
more tests.. moteino on my pocket  ;D
Post by: Felix on October 05, 2020, 09:27:01 AM
Not bad for such a small antenna!
The parts are part of impedance matching.
