I've created some open source tools to make it easier to build custom Moteino nodes. Links to code, videos and documentation are below. I hope this will help get your projects working FAST!
Arduino Libraries and MNN documentation:
https://bitbucket.org/jdolsen/moteino-node-network/src
Moteino Node Network Host:
https://bitbucket.org/jdolsen/moteino-node-network-host/src
Videos:
https://www.youtube.com/channel/UCzxmfqEhttC7tjbAsHgWoZA
I just added Arduino libraries and support for the RFM69 transceiver family. I'll test the libraries when I get some Moteinos with RFM69 transceivers! If you are able to get a project working before I can test the libraries, please post your success (or failure) here! I'm happy for feedback!
Just added a demo video where I create a new Moteino node in under 8 minutes. You can also see the longer version with explainations.
https://www.youtube.com/watch?v=vAvoydK-btE
I just completed a new project using the Moteino Node Network.
I wanted a keg scale to keep track of how much beer is left in my kegerator kegs. And I wanted the scale to notify me when the keg is nearing empty (time to brew again!). The moteino in this project reads the voltage provided by a load cell-instrumentation amplifier circuit. I got the load cell from Amazon (http://www.amazon.com/gp/product/B00NH9Q9LK/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1).
Circuit design, Circuit calibration, and physical assembly took about a day once I had all the parts. The Arduino code using the MNN libraries made programming and network integration quick and easy. I've included photos of the result.
Now that testing is complete, I just have to paint, install, and get to work on my next project.
Here are links to the source code for the keg scale and the demo.
Demo:
https://bitbucket.org/jdolsen/moteino-node-network/src/94cbd0f8bfad74437d2437c7ec58582e7e59b5ef/MNN_Demo1_short/?at=master
keg scale:
https://bitbucket.org/jdolsen/moteino-node-network/src/94cbd0f8bfad74437d2437c7ec58582e7e59b5ef/KegScaleNode/?at=master
Need to install the MNN libraries? No problem...
http://youtu.be/pfbqLYFExLQ
