Since i ordered couple of Moteino's (8mhz variant without Radio's and SPI). I would prefer to use library provided by low power lab.
In case, for testing purposes, if i intend to use it with Radio Head library, there are any software constraints i need to consider ?
SPI baud rate with RFM69 may be ?
Cheers,
Omer
The only limitation I'm aware of is the Serial baud rate is limited to 57600. No changes to the Low Power Lab library are needed.
Thanks TomWS for the reply !! :)
