Hardware support => Moteino => Topic started by: physiii on February 12, 2015, 03:55:10 AM
Title: More powersaving woes w RFM69Ext
Post by: physiii on February 12, 2015, 03:55:10 AM
I have been able to reduce the power from ~20mA to ~4mA by using Sleep_n0m1.h and RFM69Ext.h.  When I switch from using the RFM69 to RFM69Ext library I start getting errors when looking at the packets that the node is getting from the gateway. I need the node to be able to receive from the gateway every 1s, the power on the gateway doesn't matter. Could someone shine some light on this problem?
On the node I see:
Transmitting at 433 Mhz...
*4*8**
3*46*unlocked:ok!
*4*8**
3*46*locked:ok!
*0**test
3*46**test
3*46**test
3*46**test
3*46**0**test
It should say:
unlocked:ok!
locked:ok!
test
test
Here is the code:
#include <RFM69.h>
#include <RFM69Ext.h>
#include <SPI.h>
#include <Sleep_n0m1.h>
#define GATEWAYID     1
#define NODEID        2    //unique for each node on same network
#define NETWORKID     100  //the same on all nodes that talk to each other
#define FREQUENCY     RF69_433MHZ
#define ACK_TIME      30 // max # of ms to wait for an ack
#define SERIAL_BAUD   115200
#define LOCKSENSOR    7
#define MOTOR_EN      4
#define MOTOR_1       3
#define MOTOR_2       5
char message[] = "a";
char buff[20];
long lastPeriod = -1;
int unlock_delay = 100;
int lock_delay = 100;
bool requestACK = true;
bool LOCKED = false;
bool UNLOCKED = false;
bool LOCKING = false;
bool UNLOCKING = false;
bool OLD_STATE = false;
bool promiscuousMode = true;
byte ackCount=0;
//RFM69 radio;
RFM69Ext radio;
Sleep sleep;
void setup()
  Serial.begin(SERIAL_BAUD);
  char buff[50];
  Serial.println(buff);
  pinMode(LOCKSENSOR, INPUT);
  pinMode(MOTOR_1, OUTPUT);
  pinMode(MOTOR_2, OUTPUT);
  pinMode(MOTOR_EN, OUTPUT);
  radio.setHighPower();
  radio.encrypt(ENCRYPTKEY);
void loop()
  delay(200);
  radio.listen(1);
  radio.sleep();
  sleep.pwrDownMode();
  sleep.sleepDelay(300);
  radio.listen(0);
  if (OLD_STATE!=digitalRead(LOCKSENSOR))
    if (digitalRead(LOCKSENSOR))
      if (radio.sendWithRetry(GATEWAYID, "u", 1))
        Serial.println("unlocked:ok!");
      else Serial.println("unlock:nothing...");
    else
      if (radio.sendWithRetry(GATEWAYID, "l", 1))
        Serial.println("locked:ok!");
      else Serial.println("lock:nothing...");
    OLD_STATE = digitalRead(LOCKSENSOR);
  while (LOCKING)
      digitalWrite(MOTOR_EN, HIGH);
      digitalWrite(MOTOR_1, HIGH);
      digitalWrite(MOTOR_2, LOW);
    else
      delay(lock_delay);
      digitalWrite(MOTOR_1, LOW);
      digitalWrite(MOTOR_EN, LOW);
      LOCKING = false;
  while (UNLOCKING)
    if (!digitalRead(LOCKSENSOR))
      digitalWrite(MOTOR_2, HIGH);
    else
      delay(unlock_delay);
      UNLOCKING = false;
  if (radio.receiveDone())
      message = (char)radio.DATA;
    Serial.println(message);
    if (message[0] == 'u')
      UNLOCKING = true;
      LOCKING = false;
      Serial.println("unlock message received!");
    if (message[0] == 'l')
      LOCKING = true;
      UNLOCKING = false;
      Serial.println("lock message received!");
    if (radio.ACK_REQUESTED)
      radio.sendACK();
      if (ackCount++%3==0) delay(3);
    Blink(LED,1000);
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input == 's')
    if (input == 'l')
      UNLOCKING = false;
      LOCKING = true;
    if (input == 'u')
      UNLOCKING = true;
      LOCKING = false;
  pinMode(PIN, OUTPUT);
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
