I was able to load the RFM69 library into the Platformio registry using:
$ platformio lib install "RFM69"
but I cannot determine how to load the LowPower library at https://github.com/LowPowerLab/LowPower
I keep getting this error during a build:
[Mon May 22 12:53:46 2017] Processing moteino (platform: atmelavr; lib_deps: RFM69, SPIFlash, LowPower; board: moteino; framework: arduino)
Warning! Library `LowPower` has not been found in PlatformIO Registry.
You can ignore this message, if `LowPower` is a built-in library (included in framework, SDK). E.g., SPI, Wire, etc.
Verbose mode can be enabled via `-v, --verbose` option
Converting MotionShockTest_v5a.ino
I've read thru the various Library related docs on the Platformio at http://docs.platformio.org but I cannot figure this out. Can someone point me in the right direction?
What does your project directory structure look like and can you post your platformio.ini for the project?
I 'usually' set up a lib folder with symlinks to all the library folders I have. I used the term 'usually' as I've only been using platformio for a little while and I'm definitely a newbie with this tool. However, I do use LowPower library and have a link to the LowPower folder that, I believe, is unchanged from the published library.
Attached is a image of the directory structure. And here is the platformio.ini file:
; PlatformIO Project Configuration File
[env:moteino]
platform = atmelavr
board = moteino
framework = arduino
lib_deps =
RFM69
SPIFlash
LowPower
I may need to add SPI.h since I get errors
I may have figured it out (though it was a shotgun approach). I changed the platformio.ini file from this:
lib_deps =
RFM69
SPIFlash
LowPower
To this:
lib_deps =
RFM69
SPIFlash
SPI
https://github.com/LowPowerLab/LowPower.git
It doesn't make much sense to me but I think it worked!
I don't use lib_deps. I use 'lib_ldf_mode = deep' and platformio figures out what libraries I need and, as I said, goes to my local lib directory to find the library directories (which, of course, are symlinks to the real library folders).
Since I think you're on a Windows system, I'm not sure how to set that up. However, it seems to me that LowPower should be easy...
My project directory structure is:
project_name
src
project_sources (.c, .h .cpp .ino)
lib
RFM69 (link)
SPIFlash (link)
LowPower (link)
etc
platformio.ini
I thought platformio was suppose to determine what I needed! Thank you for that! I'll read about 'lib_ldf_mode = deep'. I am on a Mac (macOS Sierra).
In your "lib" folder, what is RFM69 symlinked to? Does RFM69 symlink to ~/Documents/Arduino/libraries/RFM69?
Quote from: JonM on May 22, 2017, 05:52:45 PM
Well, not in my case, but it could be in yours. As long as you have a link to where the library is actually located, it doesn't matter where it is. That's why I don't bother with registering a library, each project folder has a lib folder with links to the libraries necessary for the project. From platformio's perspective they're local libraries.
T
EDIT: By the way, this also gives me the latitude to temporarily override a particular library with an 'enhanced' version. I just change the link to point to the one-off folder instead. I don't need to mess with the stable library at all.
