Hardware support => Moteino => Topic started by: stern0m1 on January 20, 2016, 07:55:56 PM
Title: battery for Motion/OLED Mote Moteino
Post by: stern0m1 on January 20, 2016, 07:55:56 PM
is there a battery on amazon i could use with Motion/OLED Mote Moteino?
thanks
Title: Re: battery for Motion/OLED Mote Moteino
Post by: Felix on January 20, 2016, 08:28:05 PM
This should work: http://www.amazon.com/oneself-Lithium-Polymer-rechargeable-keychain/dp/B00M6L9MCS
I see adafruit also sells some of their batteries on amazon, but at a steep price boost: http://www.amazon.com/ADAFRUIT-INDUSTRIES-1578-Lithium-Polymer/dp/B011NCCXLC/
Also there is a cell phone category (http://www.amazon.com/s/ref=sr_1_5_hso_sc_smartcategory_5?rh=n%3A2407758011%2Ck%3Alithium+ion+battery&keywords=lithium+ion+battery&ie=UTF8&qid=1453338975&sr=8-5-acs) and I've had good experience with cell phone batteries. They seem to be better quality than what adafruit/sf and others are selling online.
There are 3 important things to consider when you shop for a battery:
- depending where you shop you will not get the right mating JST 2pin 2mm pitch connector (http://jst%202pin%202mm%20pitch%20connector), but you can always solder the battery to the board (mind polarity!!!) since there is a battery switch also on the MotionMote
- the size of the battery is important if you put the kit inside the provided lasercut case, should be no larger than 55*33*7mm
- it has to be a 1 cell 3.7v nominal (4.2v when fully charged) LiIon or LiPolymer battery
Also be very careful with the polarity even when you find the mating connector, my board expects it plugged the right way.
The main 2 reasons I've given up trying to offer batteries are:
- there are very strict rules and limits with shipping LiIon batteries, and most people break these rules including the big players
- finding good sources for good quality batteries is a real challenge, china is always a huge gamble with anything more complex than wires and headers
Post by: stern0m1 on January 20, 2016, 10:06:36 PM
thanks.
I have a cell phone battery that says 3.7 volts Li-ion do you think it should work? I dont know if its 1 cell and 4.2 volts when fully charged. well the voltage i could check, but i have no idea if its 1 cell.
thanks
Post by: Felix on January 20, 2016, 11:14:29 PM
If it's 3.7 it's most likely 1 cell.
Usually 2 cells are in series to form more voltage (ie double, triple etc).
You could just solder 2 wires (use black for GND and red for +). Then solder them to the MotionOLED. If all is good, it should work, it should charge up (CHRG LED should come on assuming it's not fully charged).
