good morning Gentlemen
i am having a problem with a code i wrote. is a simple remote thermometer. i want to have, at the receiver side, a lcd displaying the temperature received from another moteino.
when i include the libraries
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
the line of code
buff1 = ((char)radio.DATA);
generates the following error when compiling
mot_rec_short.ino: In function 'void loop()':
mot_rec_short.ino:76:31: error: expected unqualified-id before numeric constant
mot_rec_short.ino:76:31: error: expected ')' before numeric constant
as i suck at C, hope someone can shed some light on the mystery :-)
here the complete code
#include <RFM69.h>
#include <SPI.h>
#include <SPIFlash.h>
#include <Wire.h>
//#include <LCD.h>
//#include <LiquidCrystal_I2C.h>
#define NODEID 1 //unique for each node on same network
#define FREQUENCY RF69_915MHZ
#define ENCRYPTKEY "gianmarcorizzo12" //exactly the same 16 characters/bytes on all nodes!
#define ACK_TIME 30 // max # of ms to wait for an ack
#define LED 9 // Moteinos have LEDs on D9
#define SERIAL_BAUD 115200
#define I2C_ADDR 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
RFM69 radio;
SPIFlash flash(8, 0xEF30); //EF40 for 16mbit windbond chip
bool promiscuousMode = false; //set to 'true' to sniff all packets on the same network
Serial.begin(SERIAL_BAUD);
delay(10);
#ifdef IS_RFM69HW
radio.encrypt(ENCRYPTKEY);
radio.promiscuous(promiscuousMode);
char buff[50];
sprintf(buff, "\nListening at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
Serial.println(buff);
pinMode (3, OUTPUT);
byte ackCount=0;
char buff1[10];
long ref1 = 0;
float ref2 = 0;
if (radio.receiveDone())
ref1 = atoi(buff1);
ref2 = (ref1 / 9.31)-1.4; // calibration 1.4 deg C
Serial.println(ref2);
if (radio.ACK_REQUESTED)
radio.sendACK();
Serial.print(" - ACK sent.");
if (ref2 > 19.5)
digitalWrite(3, LOW);
Serial.println("off");
if (ref2 < 19)
digitalWrite(3, HIGH);
Serial.println("on");
Serial.println();
Blink(LED,3);
pinMode(PIN, OUTPUT);
digitalWrite(PIN,HIGH);
delay(DELAY_MS);
digitalWrite(PIN,LOW);
What does your data that you send look like? Is it an integer or a decimal number?
radio.DATA is a byte array pointer. So you can't convert it to a char.
You could use sscanf to read your integer or decimal into a variable like this:
uint16_t tmp=0;
sscanf((const char*)radio.DATA, "some text here %u more text after (if any)", &tmp);
If your variable is a float use %f instead. See this reference for all the possible printf/scanf arguments: http://www.cplusplus.com/reference/cstdio/printf/
Hi Felix
this is the code that sends data. it is a integer.
int reading = analogRead(sensorPin);
itoa(reading, buff, 10);
byte buffLen=strlen(buff);
if (radio.sendWithRetry(GATEWAYID, buff, buffLen))
Serial.print(" ok!");
else Serial.print(" nothing...");
basically all need is to receive the same integer i send from the trasmitter side, put it in some variable so i can then use it for the logic to start/stop the heating boiler.
as i said, i suck at C, the funny thing is that the receiver code works fine if i dont include the LCD libraries...
i cannibilized the code from some other moteino application, where char was used...
Hey I think the easiest way for you to transmit an integer is with the struct send/receive examples, just replace the existing variables with a single integer variable:
https://github.com/LowPowerLab/RFM69/tree/master/Examples
OR .. since int is a 2 byte you could just read the first 2 bytes from radio.DATA (like radio.DATA[0] and [1]) and make an integer with them:
uint8_t temp=0;
temp = (radio.DATA[0] << 8) + radio.DATA[1];
thanks a lot for the suggestions. however i am investigating some more, as using the lcd libraries im using, even your original receiver code breaks down
these are the libraries im using.
https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
i tried other lcd i2c libraries, they dont break the code but they dont work with my display/i2c interface
Sorry but I don't know what else to suggest, I am not familiar with those libraries.
no prob Felix.
very happy with your products. great stuff indeed.
Quote from: Felix on March 14, 2014, 12:32:42 PM
I had the same problem. I saw that there were a lot of the same pins being used for the wireless and the LCD, so for about $5 I ended up sending the data from the Moteino to another Arduino Mini clone through serial (TX/RX). The Arduino does my SPI LCD just fine. Just my 2c.
the problem must be software, as i am able to use the I2C display with the same moteino, just cant include the radio and the I2C lcd libraries at the same time
i dont think is a problem with digital outputs as the I2C uses A4 and A5
i found other I2C LCD libraries that are compatible with the moteino libraries, just they dont work with this specific I2C adapter/LCD display. which is funny as hardware looks the same.
as last resort ill get a different I2C display, neater than adding a second arduino :-)
Quote from: ShadowGrass on March 14, 2014, 06:03:51 PM
The i2c LCD I used is working without issue, as shown in the Mailbox Notifier standalone receiver: https://github.com/LowPowerLab/MailboxNotifier/blob/master/MailboxNotifier2_receiver.ino
i found a i2c LCD library that works with the RFM69 libraries, my cheap pcf8574 board, the hdm16216 lcd, and my crappy code :-) which might be wrong but due to the mysterious nature of C, nevertheless works
library downloadable (for the time being) here
http://www.divshare.com/download/24151116-7dc
Oh great, so [SOLVED]?
affirmative sir :-)
