I need to update that sketch,
In the interim, can you please try adding this to your sketch and see if it resolves it:
#if defined(__SAMD21__)
#include <avr/dtostrf.h>
#endif
Just received Moteino M0 boards, soldered BME280 breakouts on, and run your example to check my soldering and to get some grip on calibration.
The code
#endif
didn't work for me for some reason, but adding
to packages/Moteino/hardware/samd/1.3.0/cores/arduino/WString.h as a last include did the trick.
Another change I've made is replacing Serial with SerialUSB. Maybe it's worth adding M0 to the note on
https://lowpowerlab.com/guide/moteino/programming-libraries listing the boards where FTDI adapter isn't necessary?
I guess I need to change
to
and possibly the voltage formula in that sketch to the one in "Example reading the VIN" on
https://lowpowerlab.com/guide/moteino/moteinom0 too, right?
