printing RFM95 registers using the RadioHead v1.8.4 library?
Started by mikesnook, March 19, 2019, 01:29:39 PM
mikesnook
Hi all I am struggling to get my new Moteino M0 with module (RFM95 915) to communicate wirelessly, so in an attempt to check the device is able to talk to the module correctly I am just trying to run rf95.printRegisters(); nothing happens and the sketch seems to freeze as the next println doesn't output anything.
Running the Radiohead library 1.8.4:
here is the server code :
// rf95_server.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messageing server
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95  if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example rf95_client
// Tested with Anarduino MiniWirelessLoRa, Rocket Scream Mini Ultra Pro with
// the RFM95W, Adafruit Feather M0 with RFM95
#include <SPI.h>
#include <RH_RF95.h>
RH_RF95 rf95(A2, 9); //SPI CS init with MoteinoM0
#define Serial SerialUSB
int led = 9;
void setup()
  pinMode(led, OUTPUT);
  Serial.begin(9600);
  while (!Serial) ; // Wait for serial port to be available
  if (!rf95.init())
    Serial.println("init failed");
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
rf95.setFrequency(915.0);
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
//  driver.setTxPower(23, false);
  // If you are using Modtronix inAir4 or inAir9,or any other module which uses the
  // transmitter RFO pins and not the PA_BOOST pins
  // then you can configure the power transmitter power for -1 to 14 dBm and with useRFO true.
  // Failure to do that will result in extremely low transmit powers.
//  driver.setTxPower(14, true);
void loop()
  Serial.println("attempting to print registers..");
  Serial.println("finished printing registers..");
  if (rf95.available())
    // Should be a message for us now
    uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (rf95.recv(buf, &len))
      digitalWrite(led, HIGH);
//      RH_RF95::printBuffer("request: ", buf, len);
      Serial.print("got request: ");
      Serial.println((char*)buf);
//      Serial.print("RSSI: ");
//      Serial.println(rf95.lastRssi(), DEC);
      // Send a reply
      uint8_t data[] = "And hello back to you";
      rf95.send(data, sizeof(data));
      rf95.waitPacketSent();
      Serial.println("Sent a reply");
       digitalWrite(led, LOW);
    else
      Serial.println("recv failed");
Any idea what i'm doing wrong ?
If you look in RH_RF95.cpp:
bool RH_RF95::printRegisters()
#ifdef RH_HAVE_SERIAL
    uint8_t registers[] = { 0x01, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f, 0x10, 0x11, 0x12, 0x13, 0x014, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f, 0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27};
    uint8_t i;
    for (i = 0; i < sizeof(registers); i++)
	Serial.print(registers[i], HEX);
	Serial.print(": ");
	Serial.println(spiRead(registers[i]), HEX);
#endif
    return true;
It prints to Serial. Change those lines to SerialUSB in your local copy.
Or better yet, include this at the top of the file and try again:
#if defined (MOTEINO_M0)
#endif
mikesnook
Thanks for the Hardware and the code correction Felix. Works now!  :)
mikesnook
When using the MoteinoM0 are there any other settings apart from setting the freq that need to set for the client and server examples from the RadioHead Library to function (R95_Client.pde R95_Server.pde) ?
Client Code:
// rf95_client.pde
// Example sketch showing how to create a simple messageing client
// It is designed to work with the other example rf95_server
#include <SPI.h>
// Singleton instance of the radio driver
//RH_RF95 rf95;
//RH_RF95 rf95(5, 2); // Rocket Scream Mini Ultra Pro with the RFM95W
//RH_RF95 rf95(8, 3); // Adafruit Feather M0 with RFM95
// Need this on Arduino Zero with SerialUSB port (eg RocketScream Mini Ultra Pro)
void setup()
  // Rocket Scream Mini Ultra Pro with the RFM95W only:
  // Ensure serial flash is not interfering with radio communication on SPI bus
//  pinMode(4, OUTPUT);
//  digitalWrite(4, HIGH);
  Serial.begin(9600);
  if (!rf95.init())
void loop()
  Serial.println("Sending to rf95_server");
  // Send a message to rf95_server
  uint8_t data[] = "Hello World!";
  // Now wait for a reply
  if (rf95.waitAvailableTimeout(3000))
    // Should be a reply message for us now
      Serial.print("got reply: ");
    else
  else
    Serial.println("No reply, is rf95_server running?");
  delay(400);
Server Code:
// rf95_server.pde
#include <SPI.h>
//RH_RF95 rf95;
int led = 9;
void setup()
  Serial.begin(9600);
  if (!rf95.init())
void loop()
      // Send a reply
    else
Thanks,
Mike
Not that I know of, using the examples that is.
You can set several parameters for the radios (spread factor etc.).
I'm sure you can play with the registers also if you'd like.
See the .h header files and RadioHead documentation for RFM95 for what's available: http://www.airspayce.com/mikem/arduino/RadioHead/
mikesnook
Ok i cant get two MoteinoM0's + RF95 modules talking over the wireless connection using the above examples. wasn't sure if something else needed to be set in the sketch. i have brought another board in case one is faulty.
I hope this helps in some way:
Before I ship them, I test each with the RF95_client sender example. On the receiving end is the RF95_server.
