Moteino M0 - Windows 10 shows says USB device not recognized [solved]
Started by Tirititelu, July 29, 2018, 02:48:54 PM
Tirititelu
I uploaded several simple sketches in my Motenio M0 (LED Blink ...) and everything worked correctly but after uploading a skecth using the "LowPower" library Windows 10 did not recognize my Moteino, it showed the message of the subject.
I think I've left my Moteino in a "stand by" loop ...
I have a USB FTDI but I am not able to upload any skecth. Can somebody help me?.
Thank you.
Without seeing the code, I am guessing your sketch is probably making it into a USB device that is not recognized by Windows. This is very common and you can easily "brick" it if your code disables the USB or sleeps the MCU - basically making it unresponsive to further sketch uploads while YOUR sketch is running.
In all these cases the fix is:
Put it back into bootloader mode so Windows can see it as a serial device (double tap on RESET, or first reset, give it a fraction of a second, then double tap on reset) until you see the breathing LED pattern, that's how you know you're in bootloader.
