Although other board packages might work and compile, please ONLY use the Moteino SAMD package, not something else,
With the Moteino Boards 1.5.0, Serial.print now uses the USB serial. SerialUSB.print is deprecated.
If you have any code that assigns SerialUSB to Serial, that should be removed. That was implemented in some RFM69 library examples and was removed with this release. There might be leftovers on this site with that piece of code.
Other than that there is no reason why a simple print would not print to the USB serial port.
Try an empty sketch:
void setup() {
Serial.begin(1);
uint8_t count;
void loop() {
Serial.println(count++);
