Author Topic: Weathershield, Moteino Powershield sandwich  (Read 495 times)
wile1411
  • Jr. Member
  • Country: au
« on: November 21, 2018, 12:59:26 AM »
When trying to optimise my battery draw from my moteino stack, I only want to utilize the Powershields voltage divider to measure the battery level.
The catch is I've got both V1 and v2 of the weathershield...
I've already read on the forum that for V2 - it's ideal to cut to voltage divider solder jumper on the weather mote (A7)when using the powershield, but there is the question of if it would also help to remove the angled resistor too? (in case someone asks where I got the idea to remove the resistor, here's me reference info: link
for the R1, is it just a matter of cutting the trace on the back? or can there be addtional saving with desolders the mostfet and smd resistors?
« Last Edit: November 21, 2018, 09:17:00 AM by wile1411 »
Re: Weathershield, Moteino Powershield sandwich
« Reply #1 on: November 28, 2018, 09:27:57 AM »
Sorry I missed this.
On WS R2, disconnecting A7 is easy through the jumper, but you'd also want to disconnect VIN from that divider to stop the ~2uA current flowing through it - if you remove the angled resistor that is sufficient (no trace cutting).
On R1 you'd need to cut the VIN trace and perhaps A7/A3 as well. If you want to avoid cutting the A3 trace, you can leave it disconnected from the rest of the boards (remove that pin from the header) or pull it LOW in your code (in this case make sure to remove the VIN connection). For VIN you could remove the 10K resistor.
