Viewing brief low current events with the Serial Plotter Tool
Started by EdM, August 17, 2016, 05:22:28 PM
EdM
I was playing with the serial plotter  and an ADS1115, and the combination ended up being a quick way to look at power use of my dataloggers.
http://edwardmallon.wordpress.com/2016/08/15/using-the-arduino-uno-as-a-basic-data-acquisition-system/
I admit it's pretty crude, but replicating a task one would normally do with an oscilloscope without any extra software is kind of cool.
Configuring the ADC's built in comparator for triggering, and using an Moteino mega for the extra variable space, would let you whip up a half decent low power monitor without too much effort. Essentially: a data-logger-logger :-)
Ed,
Very nice one!
When I read this the first thing that went through my mind was this same ADC could be used with a Moteino for a remote uCurrent logger :)
Or of course, any low power project.
Looking at the DS it looks like the top sample rate is a rather low 860sps, but given the I2C interface that probably explains it.
What sample rate do you use it at? Are your loggers pretty constant in terms of consumption? What about when they transmit? Are the spikes I see in your article radio transmissions?
EdM
It's not the I2C that's slowing things down, as the ADC supports high speed coms if you set the right registers.  So I think(?) 860sps is a hardware limitation elsewhere. If you had multiple ADC's and synchronized them at the start of a sample run with some well timed resets, you could probably interleave the readings. Getting sensitivity of 0.0078mV with so little effort is nice, but I don't know what it's power consumption would be in a logging application.  (--insert recursion joke here--)
Those spikes are primarily from waking up the processor long enough to read/reset the I2C device registers, and in the RTC event, sending the interval sample data to an AT24C256 eeprom which buffers for a few days before the SD card dump. Power consumption on the loggers is very stable unless they are interrupt driven, so the drip sensors can burn through batteries much more quickly if they are constantly being triggered. But we still get at least 8-10 months out of them. The SD cards are the real power drain.
I have not really investigated wireless transmission yet because most of our loggers go under water, or far underground. We just save everything on SD and swap the units during service visits.  Though I do have a few Moteinos ready to play with...if I ever get that far into the never ending todo list...
I just did this test to see if it was worth adding the ADS1115's to a field instrumentation course that my wife teaches, and the serial plotter (which I had largely ignored up til now) was just a nice bonus.
