Author Topic: Trying out ListenMode  (Read 1504 times)
Neko
« on: April 05, 2017, 05:02:58 PM »
Alas, I get the following errors when I #include<listen.h).
Arduino 1.6.4 on OSX.
ListenMode branch of RFM69 library.
In file included from /Users/neko/Documents/Arduino/libraries/listen/listen.cpp:1:0:
/Users/neko/Documents/Arduino/libraries/RFM69-ListenMode/RFM69.h: In function 'void irq()':
/Users/neko/Documents/Arduino/libraries/RFM69-ListenMode/RFM69.h:167:18: error: 'virtual void RFM69::select()' is protected
     virtual void select();
/Users/neko/Documents/Arduino/libraries/listen/listen.cpp:40:20: error: within this context
     pRadio->select();
Lots of similar errors for unselect() and setMode() as well.
#include <RFM69.h>
#include <SPI.h>
#include <LowPower.h>
#include <listen.h>
// Uncomment the appropriate frequency for your hardware
//#define IS_RFM69HW    //uncomment only for RFM69HW! Leave out if you have RFM69W!
#define ENCRYPT_KEY "sampleEncryptKey"
#define ADDRESS 2
#define NETWORK_ID 100
Re: Trying out ListenMode
« Reply #1 on: April 06, 2017, 04:25:07 PM »
Here is the branch of listen mode, this needs to completely replace RFM69 if you had that installed (ie not side by side, only this one in your arduino/libraries).
Then load these examples:
https://github.com/LowPowerLab/RFM69/tree/ListenMode/Examples/ListenMode_Master
https://github.com/LowPowerLab/RFM69/tree/ListenMode/Examples/ListenMode_Node
Neko
« Reply #2 on: April 06, 2017, 05:43:24 PM »
The ListenMode branch is installed, replacing RFM69 as you suggest. The ListenMode_Master and ListenMode_Node examples work well together.
The trouble arises when I try to add the listen.h and listen.cpp, which has the nice timed delay function in it. I don't know how to add them without creating these conflicts.
Listen.h and Listen.cpp are from joelucid in reply 13 of this thread.
Is there a way to make a delay using the ListenMode branch alone?
« Last Edit: April 06, 2017, 06:55:48 PM by Neko »
« Reply #3 on: April 06, 2017, 10:00:06 PM »
joe's version might require the MAIN RFM69 branch but this was posted in september 2015 so since then the library has had some changes, though I don't really expect breaking changes, if the assumption that the RFM69 lib was used is valid. So try his sketch with the MAIN RFM69 branch.
Neko
« Reply #4 on: April 07, 2017, 12:50:39 PM »
Thanks Felix
I got it working by adapting the relevant bits (delay, delayIrq and endlistener) from joelucid's library and putting them directly into the ListenMode branch of the RFM69 library.
Can I put C++ on my resume now...
« Reply #5 on: April 07, 2017, 12:57:52 PM »
Very cool, you sure can !!
