Trouble coming out of powerDown() on arduino Mini 8mhz [SOLVED]
Started by gcl8a, January 02, 2017, 10:26:59 AM
gcl8a
Update: The underlying cause appears to be power related. The symptoms below only show up when running on battery; when running on a steady DC power supply, the system works as expected. I'm guessing the voltage regulator is to blame, but I'll do some tests to see.
The entire code is below, but the gist of it is that my sensor node won't come out of sleep properly when I try to sleep both the uC and the wireless. Four cases are presented below.
Hardware is ATmega328 (running on 8MHz internal clock) + RFM69HCW ( + HIH-6130 humidity/temperature sensor on an I2C bus). To maximize battery life, I'm taking a reading every 8 seconds and trying to put everything to sleep in between, but I'm missing something obvious, I fear.
A naive, non-sleeping sketch works just fine:
void loop()
  uint8_t status = SendTemperatureRH();  //this calls RFM69::SendWithRetry();
  delay(8000);  //just to check that it all works
Sleeping the uC works fine:
void loop(void)
Sleeping the wireless works just fine:
void loop(void)
  radio.sleep();
  delay(8000);
  radio.receiveDone(); //not sure if I really have to call this or not
But sleeping everything does not. It will report the temperature and humidity one time and then never again.
void loop(void)
  radio.sleep();
  radio.receiveDone();  //not sure if I need this or not, but I've tried it with and without
I haven't put any LEDs or other means to debug, because I'm assuming I'm missing something obvious. If not, I'm happy to entertain ideas for things to check.
Full code here:
#include <Wire.h>
#include <RFM69.h>
#include <sensor.h>
#include <hvac_defines.h>
#include "LowPower.h"
#define NETWORKID     0   // Must be the same for all nodes (0 to 255)
#define MYNODEID      OUTDOOR_WIRELESS   // My node ID (0 to 255)
// RFM69 frequency:
// AES encryption (or not):
#define ENCRYPT       false // Set to "true" to use encryption
#define ENCRYPTKEY    "TOPSECRETPASSWRD" // Use the same 16-byte key on all nodes
// Create a library object for our RFM69HCW module:
RFM69 radio;
void setup(void)
  Wire.begin();
  // Initialize the RFM69HCW:
  radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
  radio.setHighPower(); // Always use this for RFM69HCW
  radio.setPowerLevel(0); //tone it down a bit...
  // Turn on encryption if desired:
  if (ENCRYPT)
    radio.encrypt(ENCRYPTKEY);
void loop(void)
  radio.sleep();
#define HIH6130_ADDRESS 0x27
uint8_t SendTemperatureRH(void)
  Wire.beginTransmission(HIH6130_ADDRESS);
  Wire.endTransmission();
  delay(50); //it take 36 ms for the reading...should I idle?
  Wire.requestFrom(HIH6130_ADDRESS, 4);
  uint8_t hum_H = Wire.read();
  uint8_t hum_L = Wire.read();
  uint8_t temp_H = Wire.read();
  uint8_t temp_L = Wire.read();
  uint8_t status = (hum_H >> 6) & 0x03;
  if(status) return status;
  uint16_t hum16 = hum_H & 0x3f;
  hum16 <<= 8;
  hum16 += hum_L;
  uint16_t temp16 = temp_H;
  temp16 <<= 8;
  temp16 += temp_L;
  temp16 >>= 2;
  float humidity = hum16 * 0.0061039;
  SensorReading humiditySensor(OUTDOOR_HUM_SENSOR, humidity);
  SendReading(humiditySensor);
  float temperature = -40. + temp16 * 1.00714e-2;
  SensorReading temperatureSensor(OUTDOOR_TEMP_SENSOR, temperature);
  SendReading(temperatureSensor);
  return(status);
int SendReading(const SensorReading& reading)
  String sensorString = reading.TransferString();
  char buffer[24];
  sensorString.toCharArray(buffer, sizeof(buffer));
  radio.sendWithRetry(MASTER_WIRELESS, buffer, strlen(buffer));
  return 0;
