Author Topic: NDP 6020P P-Channel Mosfet Oddness  (Read 7464 times)
gregcope
  • Full Member
  • Country: gb
« on: May 07, 2017, 05:40:31 PM »
Hi.
I am trying to create a highside power switch for a GPS so that I can power it up when needed.  I also want to power its internal backup circuit, which means I cannot use a N-Channel Mosfet on the lowside/grd (as I need to connect GRD all the time).  I want to switch the GPS on for several seconds to get a fix then off.  Switching speed is not relevant.
Moteino Mega
Gate To pin 12 + 1K pull-up Resistor to 3.3V pin
Drain To GPS VIN
Source (Moteino 3.3V pin)
GRD GPS -> GRD Moteino
This is on a perfboard - hence the through hole.  Moteino and GPS are on headers.
When no GPS is connected Mosfet works fine. 3.28V to GPS VIN when pin is LOW. 0V when Pin is HIGH.
When GPS is inserted into headers I lose Serial Output from the Moteino, and only see 1.2V from the Mosfet / on the GPS VIN pin.
If I connect the GPS direct to 3.3, GRD and Pins 12/13, GPS works fine.
Oddly.  If I do a continuity check between drain and source, the GPS fires up, and serial works.
Thoughts?  Its as if the mosfet cannot quite power up the GPS.
I want to use the same High Side Switch design with a GSM module.  Hence want something that works.  On the GSM I will be switching a LIPO on / off, so slight higher volts at 4.1 or 5V if charger is on.
I am copying this design (Felix's);  https://lowpowerlab.com/2015/01/30/weathershield-is-here/
Nick Gammon has a similar example here; https://www.gammon.com.au/forum/?id=12737&reply=1#reply1
Ops.  Just noticed both examples have a resistor in series with the Pin / Gate (gate resistor?).  Can I use a 1K here? (or 560R, 100R as I have these in the parts bin).
Re: NDP 6020P P-Channel Mosfet Oddness
« Reply #1 on: May 07, 2017, 06:10:34 PM »
I don't understand what you mean by "and Pins 12/13" above.  What relevance are these if you're powering the GPS directly from 3.3V?
You don't need a resistor in series with the gate for this application unless you were controlling the rise/fall time of the drain.
gregcope
  • Full Member
  • Country: gb
« Reply #2 on: May 08, 2017, 02:17:21 AM »
Pins 12/13 on the Mega are Serial, which goto the the GPS RX/TX.
My point in that sentence, is off board, the hardware works.
Rise / fall time not relevant.  Reading around after I posted - I thought a gate resistor was there to limit current draw.
« Reply #3 on: May 08, 2017, 07:46:10 AM »
If that's true then why:
this would mean that you're modulating the gate with one of those signals rather than having a separate, solid on, power control GPIO pin.
A gate resistor WOULD be to limit current into the Gate node, but that is typically only useful if you also have a capacitor from gate to drain.  The rc time constant of the resistor/capacitor combination would control rise and fall times.
gregcope
  • Full Member
  • Country: gb
« Reply #4 on: May 08, 2017, 07:47:36 AM »
Unless someone can spot an issue with the hardware design I am going to make another to rule out odd connections and the mosfet.
gregcope
  • Full Member
  • Country: gb
« Reply #5 on: May 08, 2017, 07:49:55 AM »
Sorry Tom.  Typo on my part, 10/11 are serial.  12 is to the gate.
« Reply #6 on: May 08, 2017, 01:21:42 PM »
This FET should do what you want.  Given its size, it should be easy to measure voltage G-S and D-S when it's on.  According to your description you should have 3.3V Vgs, and <0.2V Vds.
gregcope
  • Full Member
  • Country: gb
« Reply #7 on: May 08, 2017, 03:06:19 PM »
If I have this right
G-S is -3.13V
D-S is 0V
With a 100R (to replicate 30mA load) resistor in place of the GPS Serial / mosfet works...
Would imply something wrong with the GPS.
gregcope
  • Full Member
  • Country: gb
« Reply #8 on: May 08, 2017, 03:08:57 PM »
Here is a picture of the board with 100R resistor in place of the GPS VIN/GRD (in headers)
gregcope
  • Full Member
  • Country: gb
« Reply #9 on: May 08, 2017, 03:09:23 PM »
And now with the GPS in.
gregcope
  • Full Member
  • Country: gb
« Reply #10 on: May 08, 2017, 03:19:28 PM »
Swapped out another GPS and identical issues ...
gregcope
  • Full Member
  • Country: gb
« Reply #11 on: May 08, 2017, 03:51:25 PM »
I think those measurements may have been with a resistor in.
Will repeat with a gps in.
« Reply #12 on: May 09, 2017, 09:40:13 AM »
Greg,
looking at your photos of your board, I realized that you're using Adafruit's GPS Breakout module.  This module has an onboard voltage regulator so that you can run the GPS from 5V Vin.  Now the VR has a very low dropout voltage (0.310V) but the GPS Module itself is rated to run from 3.0V to 4.3V.
Consequently, directly wiring Vin to 3.3V MAY allow the GPS module to operate, but you're out of spec with this condition and, adding the additional voltage drop of the FET, however small, may be the killer.
The 3.13V that you measured with a 100ohm load resistor is too low to operate the GPS module from Vin pin.
ISTM you have a couple of choices:
   1. the easiest change is to wire the FET output directly to the 3.3V pin of the module.  The VR in this case is a MIC5225 which actually specs this condition (implying that its an acceptable configuration) with a reverse polarity current of approximately 7.5uA with a reverse voltage or 3.3V at worst case temperature (see page 5 of https://cdn-shop.adafruit.com/datasheets/mic5225.pdf).  Your GPS should certainly run under this condition.
  2. Modify your FET circuit to feed between 3.7V to 12V the Vin input.  I'm sure you have the power supply source to do this, but you'll need an additional FET (N Channel) to control the Load Switch FET's gate with the N Channel's gate driven (with reverse logic) by the Mega.  Of course, then you're back to the problem of finding a through hole version of the N Channel FET...
gregcope
  • Full Member
  • Country: gb
« Reply #13 on: May 09, 2017, 12:51:30 PM »
Thanks for checking Tom much appreciated.   Your comments seem spot on.
gregcope
  • Full Member
  • Country: gb
« Reply #14 on: May 09, 2017, 01:52:32 PM »
Another idea.
Power directly from a pin?  With battery backup the acquisition phase should be a few seconds at most @28mA and then drop to 20mA tracking.
I plan to add an active antenna.
