Measuring power consumption while connected usb
Started by rocsta, February 12, 2016, 04:11:36 AM
rocsta
Dear all,
sorry for the prerhaps stupid question:
Is it possible to measure the power consumption of my project while the Moteino is connected for testing purposes (I would like to see the debugging output) with usb (FTDI Controller)?
I don't think so, but perhaps someone has an idea.
Kind regards,
rocsta
Quote from: rocsta on February 12, 2016, 04:11:36 AM
Dear all,
Kind regards,
rocsta
It depends...  How is your Mote powered (if from the FTDI cable then it will be hard to measure)?
Can you put your mote in modes in which the debug interface is quiet (not txing messages)?
If you are powered from another source AND you can disable the debug outputs while testing power consumption then you can get SOME accurate measures of power consumption.  The trick, if you're sleeping the processor, is to do a Serial.flush() prior to sleeping.  I also do this on return from sleep as well, but it's probably not necessary.  If you don't flush() then there will be garbage in the TX & RX buffers when you return from sleep.
I say SOME accurate measures because you need to be very careful when measuring very low power consumption (<10uA) and I wouldn't try to get these kinds of readings with a debug cable attached.
rocsta
It can be / it is powered with a separate power supply.
After send to sleep, no more text messages will appear
That's nice, but how ?  ;D
Yes, I do this.
Of course SOME. During testing the different code it's stupid to go on as follows:
1 Implement (I use now ATMEL Studio 7 with Visual Micro AddOn - very nice ... - much better than Arduino interface)
2 Upload new Software
3 Unplug ftdi
4 restart mote
5 stare on LED, until it goes sleeping (BLINKBLINK  :D )
6 check consumption
7 plug ftdi
GOTO 1
