Low power reading of DIP switches inputs on Moteino [how-to]
Started by yoopee, August 24, 2016, 05:40:57 AM
yoopee
hi,
I'm trying next low power thing, the Moteino configuration through the DIP switch and pull up resistors. I want to configure my TX packet interval with four state DIP switch. But if I am using the INPUT_PULLUP function, the power consumption goes up to 400uA when all four digital pins HIGH. Too much for low power.
I was thinking about using another digital pin as "power" instead using baterry pin and switch this pin to HIGH only when reading configuration from the DIP.
Or using external pullup resistor with higher resistance, such as megaohms?
anyone here dealt with the same problem?
Thank you
Yes, just use a power pin when you do the reading.
Once done reading make the inputs OUTPUTs and set them to LOW.
yoopee
