Human Solderable Low Power RTC
Started by phibes4000, May 28, 2017, 06:58:59 AM
phibes4000
Any recommendations for a low-power RTC that can run at <=3.3V and is in a human-solderable package?  I can do SMD with hot air, but draw the line at 'no lead' options like QFN - no reflow just yet.  I really like the features of the Abracon and Ambiq RTCs but they are QFN.
I'm more concerned with low power consumption than accuracy - a drift of 1-5s/day is OK, and would be compensated for with an hourly radio-based sync (poor-man's NTP - a long way from PTP).
Being able to handle interrupts and have the 328P MCU effectively slaved to RTC (as the AB1805 can do) is a nice to have to minimise power use.
Thanks,
Lee
Dallas Semiconductor had some SOIC/TSSOP RTCs that are accurate and 'solderable'.  The AM18x5 is tough to beat from a quiescent current perspective, but tricky to solder.
If your budget is in the single to low double digit uA domain, the DS chips will probably work for you.
captcha
I've been using the MCP79410-I/SN with great success to revive my Mega328 from sleep. Comes in SOIC package (biggest size under DIP, very much hand solderable).
Product page here:
http://www.microchip.com/wwwproducts/en/MCP79410
Pricing as per RS is around AU$1.45
http://au.rs-online.com/web/p/real-time-clocks/7263949/
power consumption about 1.2uA @ 3.3V
phibes4000
Thanks. That MCP chip looks pretty good. If it had support for an external interrupt it would be ideal.
Actually, I forgot about a chip I used a few years ago, PCF2129A, from NXP.  0.65uA, +/-3PPM with INTERNAL TXCO, 20pin SOIC, either SPI or I2C interface and lots of interrupt choices.
I forgot because its too big for most of my applications now, but it is a very nice chip...  Did I mention +/-3PPM with INTERNAL oscillator - no xtal needed.
phibes4000
Quote from: TomWS on May 28, 2017, 09:13:44 AM
It won't handle a pulse interrupt (can do simple interrupt on pin change vs ground), but otherwise looks very nice.  Includes a temperature sensor!
