Gateway_ATC_WL + Feather 32U4 = Listening mode issue...
Started by xavier, June 18, 2016, 05:58:56 PM
xavier
Got some Adafruit RFM69 to try out ( https://learn.adafruit.com/adafruit-feather-32u4-radio-with-rfm69hcw-module/pinouts ) and got the thing to work w my existing moteino hub after updating the pinouts in RFM69.h as follow:
#if defined(__AVR_ATmega32U4__)
    #define RF69_SPI_CS      8
    #define RF69_IRQ_PIN     7
    #define RF69_IRQ_NUM    4  // Pin 7 is IRQ 4!
    #define RFM69_RST     4
#end
Works fine with existing sample code but somehow I can't figure out why I can't use the listening mode ( using the sample code Gateway..._WL and Node..._WL) - the radio is the same than on moteino and I suppose I have the IRQ pin correctly since the node (32u4) can send packets to my moteino hub.
Any idea what I missed?
Thanks in advance for any pointers...
X
PS: it seems w the Feather board I need to reset the radio fyi - without that none of my packets get sent. that's been the only difference so far w the moteino. not sure how relevant that is...
Edit 1: Wanted to point out Node_ATC and Gateway_ATC sample code works just fine w 2 feathers...
