RFM12B and cli [solved]
Started by ianselmi, June 19, 2014, 07:25:14 PM
ianselmi
Hi to all,
I wrote some test to use moteino to read a water flow meter like this http://www.seeedstudio.com/forum/viewtopic.php?f=4&t=989&start=0
To read a values I used a interrupt. If I test the code on arduino it's works fine.
If I test the code on moteino with radio enabled the code hang.
If I test the code on moteino without radio enabled the code works fine.
The the code is the follow:
#include <RFM12B.h>
volatile int NbTopsFan; //measuring the rising edges of the signal
double Calc;
double LitriTotali = 0;
unsigned long startMillis = 0;
const int ledPin = 9;
typedef struct {
	int temperature, tzdst;
	double wh_gen, wh_consuming;     //variables to store cumulative power being generated, consumed, dumping
}  PayloadGLCD;
PayloadGLCD emonglcd;
RFM12B radio;
// RFM12B Settings
#define MYNODE 25           // Should be unique on network, node ID 30 reserved for base station
#define freq RF12_868MHZ     // frequency - match to same frequency as RFM12B module (change to 868Mhz or 915Mhz if appropriate)
#define group 210            // network group, must be same as emonTx and emonBase
void rpm()     //This is the function that the interupt calls
	NbTopsFan++;  //This function measures the rising and falling edge of the hall effect sensors signal
void setup()
	radio.Initialize(MYNODE, freq, group);
	Serial.begin(9600);
	Serial.println("initialing...");
	attachInterrupt(1, rpm, RISING);
void loop()
	Serial.print(" loop ");
	Serial.print(" 1 ");
	sei();
	delay(1000);
	cli();
	Serial.print(" radio ");
	int i = 0; while (!radio.CanSend() && i<10) { radio.ReceiveComplete(); i++; }
	Serial.print(" send ");
	radio.SendStart(0, &emonglcd, sizeof emonglcd);
	Serial.print(" wait ");
	radio.SendWait(0);
	Serial.print(" end ");
The code hang also if I wrote attachInterrupt(0, rpm, RISING);
I use moteino R2 and RFM12B.
Can someone help me?
Thanks a lot for help
RFM12b is using interrupt 0. Use interrupt 1 instead.
ianselmi
