listenModeSendBrust generates a "Soft WDT reset"
Started by juan3211, June 04, 2020, 04:17:59 PM
juan3211
Hi, I dont know well how ESP8266 yield and delay(0) stuff work
What I have check is that an sketch that works with Arduino Pro Mini, doesn't work with ESP8266.
It works if I comment listenModeSendBrust
I mean, it means that pin connection and the sketch itself if ok.
Does anybody try to use listenMode with an ESP8266. (in this case, ESP8266 is the TX node).
Probably it is because any internal loop in listenModeSendBurst code that make ESP8266 Soft WDT reset ?
(I have tried adding before and after that line a "delay(0);" but ESP8266 resets itself)
Thanks a lot.
Stack trace is not always the same, is it another reason about delay() yield() stuff?
0x4020cd1f: SPIClass::beginTransaction(SPISettings) at ..\esp8266\hardware\esp8266\2.7.1\libraries\SPI\SPI.cpp line 145
0x401006f1: __digitalWrite(uint8_t, uint8_t) at ..\esp8266\hardware\esp8266\2.7.1\cores\esp8266\core_esp8266_wiring_digital.cpp line 86
0x4020b5c9: RFM69::select() at ..\libraries\RFM69_LowPowerLab\RFM69.cpp line 502
0x4020b6e7: RFM69::readReg(unsigned char) at ..\RFM69_LowPowerLab\RFM69.cpp line 468
0x4020c4bb: RFM69::listenModeSendBurst(unsigned char, void const*, unsigned char) at ..\RFM69_LowPowerLab\RFM69.cpp line 1203
0x4020e96c: __esp_yield() at ..\esp8266\hardware\esp8266\2.7.1\cores\esp8266\core_esp8266_main.cpp line 119
0x4020f6a9: __delay(unsigned long) at ..\esp8266\hardware\esp8266\2.7.1\cores\esp8266\core_esp8266_wiring.cpp line 57
0x40202422: loop() at ..\diyBMS\diyBMS_Wemos_200605/diyBMS_Wemos_200605.ino line 1256
0x4020ea84: loop_wrapper() at ..\esp8266\hardware\esp8266\2.7.1\cores\esp8266\core_esp8266_main.cpp line 197
0x4020b5d4: RFM69::select() at ..\libraries\RFM69_LowPowerLab\RFM69.cpp line 503
0x4020b6e7: RFM69::readReg(unsigned char) at ..\libraries\RFM69_LowPowerLab\RFM69.cpp line 468
0x4020c4bb: RFM69::listenModeSendBurst(unsigned char, void const*, unsigned char) at ..\libraries\RFM69_LowPowerLab\RFM69.cpp line 1203
This ESP forum was created at the request of TomWS and others who've done lots of ESP development and can chime in to answer questions.
Sorry to say but I cannot offer any official support for ESP platform at the moment, since LowPowerLab makes no hardware based on ESP+RFM69.
Also, the native listen mode of RFM69 are not supported because it was reported to be less than stable.
juan3211
Thanks a lot Felix, I understand. I will publish the solution if I find it, thanks
