Cheap thermistor vs 1-Wire DS18B20?
Started by Richard, January 24, 2015, 08:45:27 PM
jra
The last time I actually used a thermistor was back in graduate school during the Carter administration when linearization was accomplished via suitable selection of a series or parallel resistor.  State of the art has advanced somewhat since then. I would look for a library that uses the Steinhart-Hart equation if you can determine/calculate the coefficients for the thermistor you plan on using.
Quote from: jra on December 17, 2018, 04:48:41 PM
All the ones I saw cited the Steinhart-Hart equation.  This library looked interesting: https://github.com/YuriiSalimov/NTC_Thermistor because the constructor used standard thermistor parameters (from the Thermistor datasheet) for setting the equations internally and the methods were straightforward.  That his Fritzing diagram is incorrect is bothersome...
