CurrentRanger with LTC2400 (ADC 24 bit)
Started by alexsh1, November 21, 2018, 12:58:58 PM
alexsh1
Did you consider using a higher resolution ADC for the CR?
I am currently working on a MilliVolt Meter based on LTC2400, voltage reference LT1019.
The resolution of this ADC is enough to make 6.5 digit meter.
Regards
Alex
Yes, sort of, but not quite 24bit, that much resolution does not buy you much, unless you have very special other components to reduce noise by 1 to 2 orders of magnitude.
One of my prototypes used an external SPI DAC but it was too:
- costly
- noisy
- slow
- lots of code, separate library
So in the end I decided to compromise with the SAMD21 DAC, which works just fine.
alexsh1
Yeah, resolution is one thing and another thing is that as you rightly pointed out the analogue section must be supporting it. Otherwise, it will be super noisy. I suppose at the end of the day, it all comes to costs. Your time is a cost element too.
In my experiments, having an external high resolution ADC, vs the benefits, there is no real advantage.
Once I decided to use the SAMD21, which has a pretty decent and usable 12bit ADC, there was no incentive to add another part and supporting circuitry to the BOM.
Plus, even a good 16bit ADC is pretty expensive.
People may not realize but any extra parts (even passives) add up not just a multiplier component cost, but also other complications, all the way from sourcing, to assembly - extra room in pick and place, to testing etc.
