Low budget oscilloscope
Started by stern0m1, January 22, 2018, 05:24:07 PM
stern0m1
I ended up going with the Rigol DS1054...
I searched high and low and I found it indeed the biggest bang for my buck...
thanks
It all started with a Moteino!
It's quite great, you will like it.
I wish it had a digital filter and I wish it could hide the sides for a larger signal view ... but oh well! :-X
stern0m1
Is there pc software  I can  use with Rigol ds1054z to record/playback analyze? Really the main thing I want is to be able to share a recorded  file with someone.
I dont see how to record and play back with Ultra scope and ultra station if relevant is not working by me.
LukaQ
Quote from: stern0m1 on February 13, 2018, 10:24:37 PM
Don't use PC SW, it is not good. But you can put usb stick into scope and take screen pictures of it, the is probably the way to go
The scope allows saving CSV data and other formats along with bitmap screen captures.
jra
If you are a Linux user you can use DSRemote/ to control/communicate your scope via LAN or USB.  I can verify that it works on a Rigol DS1054Z via LAN running Linux Mint 17.3, YMMV on other distributions.  99% of the time I use it just to capture screen dumps.
