SPIFlash::initialize() hanging
Started by snorp, April 26, 2016, 10:33:44 AM
snorp
I've been playing with my first batch of Moteinos that are flash-enabled, and frequently when resetting the device after programming via FTDI, SPIFlash::initialize() will hang. It seems to be the wakeup() call that causes this. Does anyone know why this happens? I do sleep() the flash during the normal startup sequence, so I guess that may be part of the problem. I found one thread suggesting a 10k pulldown on MISO, but that seemed to make the radio act funny (wouldn't receive packets in listen mode).
WhiteHare
#1
It's a known problem.  Here's the exact answer:  https://lowpowerlab.com/forum/index.php/topic,1714.msg12473.html#msg12473
snorp
#2
Hmm. It looks like you still need the pulldown on D12 regardless of the Arduino version? Seems kinda unlikely to be a compiler issue, no? I wish someone with a logic analyzer would figure it out. Really annoying, and like I said, the pulldown seems to screw up the radio somehow for me.
EDIT: undefining SPI_HAS_TRANSACTION in SPIFlash.h does not seem to help things, so I think that may have been a red herring in the other thread.
WhiteHare
You really should re-read the link I gave you more carefully.  I'm skeptical a megaohm pulldown resistor is going to screw up your radio.
snorp
The reason wakeup() hangs is because it's stuck waiting on busy() to return false. The status register continuously returns 0xff, which just seems to be bogus. If I just treat 0xff as non-busy, the rest of the initialization goes fine. The write-enable latch status is correctly set, etc. Removing the wakeup() call in initialize() would also work, but it seems like it would be necessary, right? If we do a reset without a power cycle, the flash should be sleeping so why does this work?
WhiteHare
#5
Well, at least you're asking the right questions....  I hope you find (and post) a better solution.  I wish I had all the answers, but I don't.  Everything I know or found out is already documented in that other thread.  I think the problem is probably both compiler and hardware related, because reverting to the earlier IDE by itself doesn't completely fix things.
snorp
Quote from: WhiteHare on April 26, 2016, 01:43:36 PM
Hmm, which part? You were pretty clear with:
[Edit: I do, however, still need the megaohm pulldown resistor on D12 if I am to wake-up the flash memory after explicitly putting the flash memory to sleep.  Without the pulldown, even if the R4 firmware is built using IDE 1.0.6, the result is still in a hang when trying to wake the flash memory.   :(  The unit I tested is an R4 running direct from two AA batteries and with the stock LDO voltage regulator removed.]
I don't see how the IDE version is in play if they behave the same and you still need the pulldown...
I was using a 10k resistor, but I'll try a megaohm one.
WhiteHare
#7
You might try experimenting with bypass capacitors.  My current hypothesis is that the megaohm resistor provides an alternate path to ground for noise, and, if so, a cap would probably be a better conduit.  That connecting DTR to ground worked at all is, I think, evidence in support of that theory.  Some perhaps weaker evidence is the presence of RSSI noise that's measurable when a Moteino is inside a sealed metal can and with its antenna shorted to ground.  Alternately, if you have the right fancy equipment, which I can only wish that I did, you might be able to measure it directly.
