Switchmote - Reduced parts
Started by txbirds, July 25, 2018, 09:05:30 AM
txbirds
Felix, Love your stuff - Thanks!
Is it possible for you to sell the Switchmote kit minus the relay(s) and power supply?
I am considering a custom installation and the relays / power supply would be redundant. Just asking. Thanks.
Thanks for the feedback  ;)
Reduced: Yes it's possible.
Q1: Will you use this with Moteinos?
Q2: How would you provide power though? The DC side expects 5V (it's just some passives and NPNs so it could be less actually but testing was done at 5V)
txbirds
Q1 - Yes, used with Moteinos.
Q2 - Plan on using 5VDC power supply which will be powered by UPS.
We see a lot of brown conditions and have even suffered through a lighting strike. Would like to separate the power so the Moteinos are protected. Probably overkill, but....
I see,
But if you're not using the RECOM PSU (supplying your own 5V via UPS sounds like), and not using the relays either, then what's the rationale of using the SM3-PSU board at all?
