Hardware support => General topics => Topic started by: javiercuellar on May 08, 2016, 07:01:38 PM
Title: SPI Flash read/write int
Post by: javiercuellar on May 08, 2016, 07:01:38 PM
Hi.
I need to store a series of array of integers to flash mem. As far as I know the functions avaliale for these are:
readByte, readBytes, writeByte, writeBytes
Very basic, so I guess I need to program a way to store integer.
Correct me please please in these pseudocode:
for each element of int array  //  ex. {1600,500,1800,300,10,2500}
   read int
   split into 2 byte
   save byte1
   save byte2
end for
Maybe you can point me to an already created example for this.
Regards
Javier
Title: Re: SPI Flash read/write int
Post by: TomWS on May 08, 2016, 07:13:41 PM
Quote from: javiercuellar on May 08, 2016, 07:01:38 PM
Hi.
   read int
   split into 2 byte
   save byte1
   save byte2
end for
Regards
Javier
You don't need to split the multi-byte value.  If you use writeBytes with the address of the variable (cast as a byte pointer) and the sizeof the object, you can store as many bytes as the size of your object, including an entire array of integers.
UPDATED: to include array of integer comment.
Post by: javiercuellar on May 09, 2016, 02:05:48 AM
Excelente Tom!!! Thanks.
Just as example for anyone else.
#include <SPIFlash.h>    //get it here: https://github.com/LowPowerLab/SPIFlash
unsigned int data[] = {8950,4400,700,1550,700,1600,650,450,600,500};
unsigned int data1[100]={};
char input = 0;
#ifdef __AVR_ATmega1284P__
  #define FLASH_SS      23 // and FLASH SS on D23
#else
  #define FLASH_SS      8 // and FLASH SS on D8
SPIFlash flash(FLASH_SS, 0xEF30);
  Serial.begin(9600);
  Serial.print("Start...");
  if (flash.initialize())
    Serial.println("Init OK!");
  else
    Serial.println("Init FAIL!");
  delay(1000);
  Serial.print("DataSize: ");
  Serial.println(sizeof(data));
  Serial.println("Input:");
  Serial.println("d: to dump all values from 0 to 4100 bytes");
  Serial.println("e: to erase the whole flash");
  Serial.println("b: to erase 1 block (4096 bytes:");
  Serial.println("1: to save values into flash");
  Serial.println("2: to read values from flash and dump them to serial");
  if (Serial.available() > 0) {
    input = Serial.read();
    int counter = 0;
    switch (input){
      case 'd':   // dump a little more than 4Kb
        Serial.println("Flash content:");
        while(counter<=4100){
          Serial.print(counter);
          Serial.print(": ");
          Serial.println(flash.readByte(counter++), DEC);
        break;
      case 'e':   //erase whole data
        Serial.print("Erasing Flash chip ... ");
        flash.chipErase();
        while(flash.busy());
        Serial.println("DONE");
        break;
      case 'b':  // erase 1 block  (4K)
        Serial.println("Erasing 4K from position 1");
        flash.blockErase4K(1);
        break;
      case '1':  // Save to flash, from position 1 the int array in data
         Serial.println("Saving...");
           flash.writeBytes(1, &data,sizeof(data));
         Serial.println("Done");
         break;
      case '2':  // Reads from position 1, into array data1,
         Serial.println("Reading....");
           flash.readBytes(1, data1, sizeof(data));
           for (int i=0; i<sizeof(data1);i++)
            Serial.print(i);
            Serial.print(": ");
            Serial.println(data1[i]);
         break;
