Hardware support => General topics => Topic started by: rfm69_868 on December 13, 2017, 07:42:06 AM
Title: RFM69HW
Post by: rfm69_868 on December 13, 2017, 07:42:06 AM
Hello everyone,
I am trying to establish a communication between two rfm69HW at 868MHz since quite a while. I'm using an arduino mega 2560 for the transmission (I have a level shifter between the mega (5v) and the rfm69 that works in 3.3V), and an arduino mini-pro for the reception (please see attachments). I actually did succeed to make them communicate, but It seems to work only when I physically get my hand very close to the reception board (the mini-pro)... Since I'm not an RF expert, can you please help me to understand what kind of radio trick am I confronted to ? Has it anything to do with the antenna ground plane ? Any idea ?
Ps (important) : I already tried to change the arduino (for reception and transmission), and even change the RFM69 board itself, it does not get any better, same problem. I even tried to change the code and libraries, but the problem seems to be hardware here. I also tried to sold the rfm69 and an arduino nano on a PCB board (see attachment "reception node on pcb"), does not change the behavior)
Any help is welcome (and needed ...)  ::)
Thanks in advance !
Here is the reception code:
#include <RFM69.h>
#include <SPI.h>
#include <SPIFlash.h>
#define NODEID     1
#define NETWORKID   100
#define FREQUENCY   RF69_868MHZ //Match this with the version of your Moteino! (others: RF69_433MHZ, RF69_868MHZ)
#define KEY         "sampleEncryptKey" //has to be same 16 characters/bytes on all nodes, not more not less!
#define LED         9
#define SERIAL_BAUD 115200
#define ACK_TIME    30  // # of ms to wait for an ack
#define IS_RFM69HW_HCW  //uncomment only for RFM69HW/HCW! Leave out if you have RFM69W/CW!
RFM69 radio;
SPIFlash flash(8, 0xEF30); //EF40 for 16mbit windbond chip
bool promiscuousMode = false; //set to 'true' to sniff all packets on the same network
typedef struct {
  int           nodeId; //store this nodeId
  unsigned long uptime; //uptime in ms
  float         temp;   //temperature maybe?
} Payload;
Payload theData;
  Serial.begin(SERIAL_BAUD);
  delay(10);
#ifdef IS_RFM69HW_HCW
  radio.setHighPower(); //must include this only for RFM69HW/HCW!
  radio.encrypt(KEY);
  radio.promiscuous(promiscuousMode);
  char buff[50];
  sprintf(buff, "\nListening at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
  Serial.println(buff);
  if (flash.initialize())
    Serial.println("SPI Flash Init OK!");
  else
    Serial.println("SPI Flash Init FAIL! (is chip present?)");
byte ackCount=0;
  //process any serial input
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input == 'r') //d=dump all register values
      radio.readAllRegs();
    if (input == 'E') //E=enable encryption
      radio.encrypt(KEY);
    if (input == 'e') //e=disable encryption
      radio.encrypt(null);
    if (input == 'p')
      promiscuousMode = !promiscuousMode;
      Serial.print("Promiscuous mode ");Serial.println(promiscuousMode ? "on" : "off");
    if (input == 'd') //d=dump flash area
      Serial.println("Flash content:");
      int counter = 0;
      while(counter<=256){
        Serial.print(flash.readByte(counter++), HEX);
        Serial.print('.');
      while(flash.busy());
      Serial.println();
    if (input == 'D')
      Serial.print("Deleting Flash chip content... ");
      flash.chipErase();
      Serial.println("DONE");
    if (input == 'i')
      Serial.print("DeviceID: ");
      word jedecid = flash.readDeviceId();
      Serial.println(jedecid, HEX);
  if (radio.receiveDone())
    Serial.print('[');Serial.print(radio.SENDERID, DEC);Serial.print("] ");
    Serial.print(" [RX_RSSI:");Serial.print(radio.readRSSI());Serial.print("]");
    if (promiscuousMode)
      Serial.print("to [");Serial.print(radio.TARGETID, DEC);Serial.print("] ");
    if (radio.DATALEN != sizeof(Payload))
      Serial.print("Invalid payload received, not matching Payload struct!");
    else
      theData = *(Payload*)radio.DATA; //assume radio.DATA actually contains our struct and not something else
      Serial.print(" nodeId=");
      Serial.print(theData.nodeId);
      Serial.print(" uptime=");
      Serial.print(theData.uptime);
      Serial.print(" temp=");
      Serial.print(theData.temp);
    if (radio.ACKRequested())
      radio.sendACK();
      Serial.print(" - ACK sent.");
      // When a node requests an ACK, respond to the ACK
      // and also send a packet requesting an ACK (every 3rd one only)
      // This way both TX/RX NODE functions are tested on 1 end at the GATEWAY
      if (ackCount++%3==0)
        Serial.print(" Pinging node ");
        Serial.print(theNodeID);
        Serial.print(" - ACK...");
        delay(3); //need this when sending right after reception .. ?
       if (radio.sendWithRetry(theNodeID, "ACK TEST", 8, 0))  // 0 = only 1 attempt, no retries
          Serial.print("ok!");
       else Serial.print("nothing");
    Serial.println();
    Blink(LED,3);
// Serial.println("fuck end");
  pinMode(PIN, OUTPUT);
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
Transmission code:
#include <RFM69.h>
#include <SPI.h>
#define NODEID      99
#define GATEWAYID   1
#define LED         6
int TRANSMITPERIOD = 300; //transmit a packet to gateway so often (in ms)
byte sendSize=0;
boolean requestACK = false;
RFM69 radio;
typedef struct {
} Payload;
Payload theData;
  radio.encrypt(KEY);
  char buff[50];
  else
long lastPeriod = -1;
    if (input >= 48 && input <= 57) //[0,9]
      TRANSMITPERIOD = 100 * (input-48);
      if (TRANSMITPERIOD == 0) TRANSMITPERIOD = 1000;
      Serial.print("\nChanging delay to ");
      Serial.print(TRANSMITPERIOD);
      Serial.println("ms\n");
    if (input == 'r') //d=dump register values
    //if (input == 'E') //E=enable encryption
    //  radio.encrypt(KEY);
    //if (input == 'e') //e=disable encryption
    //  radio.encrypt(null);
      int counter = 0;
        Serial.print('.');
      Serial.println();
    if (input == 'e')
      Serial.print("Erasing Flash chip ... ");
      flash.chipErase();
    if (input == 'i')
  //check for any received packets
      radio.sendACK();
      Serial.print(" - ACK sent");
      delay(10);
    Blink(LED,100);
    Serial.println();
  int currPeriod = millis()/TRANSMITPERIOD;
  if (currPeriod != lastPeriod)
    //fill in the struct with new values
    theData.nodeId = NODEID;
    theData.uptime = millis();
    theData.temp = 91.23; //it's hot!
    Serial.print("Sending struct (");
    Serial.print(sizeof(theData));
    Serial.print(" bytes) ... ");
    if (radio.sendWithRetry(GATEWAYID, (const void*)(&theData), sizeof(theData)))
      Serial.print(" ok!");
    else Serial.print(" nothing...");
    Serial.println();
    Blink(LED,1000);
    lastPeriod=currPeriod;
  delay(DELAY_MS);
Title: Re: RFM69HW
Post by: TomWS on December 13, 2017, 08:16:31 AM
The problem is in your creation of your 'radio' object.  You're using default values rather than specifically stating that you're using an RFM69HW.  The prototype is:
RFM69(uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN, bool isRFM69HW=false, uint8_t interruptNum=RF69_IRQ_NUM)
As you can see, the default is FALSE for isRFM69HW.
In your case, you need:
RFM69 radio(RF69_SPI_CS, RF69_IRQ_PIN,true);
Title: Re: RFM69HW
Post by: rfm69_868 on December 13, 2017, 11:42:59 AM
Quote from: TomWS on December 13, 2017, 08:16:31 AM
Hi Tom,
First of all thanks for your quick answer.
I have just tried to modify the code with your line, doesn't change anything to the problem. I dont receive anything unless I approach my hand very close to the receiver arduino board... When I do, I always receive messages
Did this kind of phenomena happen to anyone please ?? =/
I also have the following error on the screen monitor when I run the code:
Which means that the initialization doesnt work great... But I'm not sure it's a part of the problem (looks more hardware/RF...)
Title: Re: RFM69HW
Post by: TomWS on December 13, 2017, 02:35:32 PM
Did you change the code on both ends of the connection?
The phenomenon occurs whenever the radio is misconfigured for the radio type.
Title: Re: RFM69HW
Post by: rfm69_868 on December 14, 2017, 04:36:30 PM
Hi Tom,
I did change the code on both ends of the connection. Still have the same phenomenon at the reception board. I seriously suspect an hardware issue...
One important detail : I previously suplied the RFM69 with +5V, I didnt know It was a 3.3V chip... Even the fast RF signals were sent with the wrong high level (5v instead of 3.3) during quite a while... According to the datasheet, I widely exceeded the voltage limitations...  (please see attachment)
Do you think that my observations could be a consequence of this hardware error ?
Title: Re: RFM69HW
Post by: TomWS on December 14, 2017, 05:57:36 PM
Quote from: rfm69_868 on December 14, 2017, 04:36:30 PM
Well, it's always a guessing game when the hardware is stressed and the easiest test is another radio...
Another possibility is that the radio is not a 868/915 radio.  This has been known to happen, although rarely.  In this latter case, the radio would still work, it just wouldn't work as well as one with the proper RF network.
