Hardware support => General topics => Topic started by: jackpot on November 04, 2017, 01:29:30 PM
Title: RFM69HW and Particle Photon
Post by: jackpot on November 04, 2017, 01:29:30 PM
I am trying to get a pair of RFM69HW modules talking by using a Particle Photon. I have had limited success in that I can send a message to one, send an ACK back to the other but I am not able to see the RX_RSSI of the TX module. The modules I am using are here (https://www.aliexpress.com/item/RFM69HW-433Mhz-RFM12B-HopeRF-Wireless-Transceiver-RFM69HW-433S2-for-Remote-HM-Free-Shipping/32802346626.html?spm=a2g0s.9042311.0.0.7alzKA).
The code on my TX side is
#include "RFM69-Particle.h"
#include "RFM69_ATC.h"
#include "RFM69registers.h"
// Adjustments to library to work with Particle Photon including in Web IDE by Jurie Pieterse
// Forked library for Photon at https://github.com/bloukingfisher/RFM69/
// Serial NOT required to confirm working - you can watch your Particle Console logs!
/* RFM69 library and code by Felix Rusu - [email protected]
// Get libraries at: https://github.com/LowPowerLab/
// Make sure you adjust the settings in the configuration section below !!!
// Copyright Felix Rusu, LowPowerLab.com
// Library and code by Felix Rusu - [email protected]
// License
// Foundation; either version 3 of the License, or
// This program is distributed in the hope that it will
// be useful, but WITHOUT ANY WARRANTY; without even the
// implied warranty of MERCHANTABILITY or FITNESS FOR A
// PARTICULAR PURPOSE. See the GNU General Public
// License for more details.
// You should have received a copy of the GNU General
// Public License along with this program.
// If not, see <http://www.gnu.org/licenses></http:>.
// Licence can be viewed at
// http://www.gnu.org/licenses/gpl-3.0.txt
// Please maintain this license information along with authorship
// and copyright notices in any redistribution of this code
// *********** IMPORTANT SETTINGS - YOU MUST CHANGE/CONFIGURE TO FIT YOUR HARDWARE *************
int16_t NETWORKID = 100;  //the same on all nodes that talk to each other
int16_t NODEID = 2;       //make sure NODEID differs between nodes
int16_t RECEIVER = 1;     //receiver's node ID
//Match frequency to the hardware version of the radio on your Feather
//#define FREQUENCY     RF69_433MHZ
#define FREQUENCY     RF69_868MHZ
//#define FREQUENCY      RF69_915MHZ
#define ENCRYPTKEY     "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
#define IS_RFM69HCW    true // set to 'true' if you are using an RFM69HCW module
#define RFM69_CS      A2
#define RFM69_IRQ     2
#define RFM69_IRQN    2 //On Photon it is the same unlike Arduino
#define RFM69_RST     6
int16_t packetnum = 0;  // packet counter, we increment per xmission
RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HCW, RFM69_IRQN);  //initialize radio with potential custom pin outs; otherwise you may use for default: RFM69 radio;
// ***********                  Wiring the RFM69 Radio to Photon                  *************
/* Arduino wiring provided for reference, color
    Photon      Arduino     RFM69 Color
    GND         GND         GND     Black
    3V3         3.3V     VCC     Red
    A2          10         NSS     Yellow
    A3          13         SCK     Green
    A5          11         MOSI Blue
    A4          12         MISO Violet
    D2          2         DI00 Gray
                            ANA     Antenna
    D6                      RST     Optional
void setup()
    Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
    Particle.publish("RFM69 TX Startup setup","Completed",360,PRIVATE);
    Particle.publish("WiFi signal",String(WiFi.RSSI()),360,PRIVATE);
    Serial.println("RFM69 Based Transmitter");
    // Hard Reset the RFM module - Optional
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, HIGH);
  delay(100);
  digitalWrite(RFM69_RST, LOW);
  delay(100);
    // Initialize radio
  if (IS_RFM69HCW) {
    radio.setHighPower();    // Only for RFM69HCW & HW!
  // To improve distance set a lower bit rate. Most libraries use 55.55 kbps as default
  // See https://lowpowerlab.com/forum/moteino/rfm69hw-bit-rate-settings/msg1979/#msg1979
  // Here we will set it to 9.6 kbps instead
  radio.writeReg(0x03,0x0D); //set bit rate to 9k6
  radio.writeReg(0x04,0x05);
  radio.setPowerLevel(10); // power output ranges from 0 (5dBm) to 31 (20dBm)
                          // Note at 20dBm the radio sources up to 130 mA!
                         // Selecting a power level between 10 and 15 will use ~30-44 mA which is generally more compatible with Photon power sources
                        // As reference, power level of 10 transmits successfully at least 300 feet with 0% packet loss right through a home, sufficient for most use
  radio.encrypt(ENCRYPTKEY);
  Serial.print("\nListening at ");
  Serial.print(FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
  Serial.println(" MHz");
//=========================MAIN LOOP===========================================
  Serial.print("."); //THis gives us a neat visual indication of time between messages received
  char radiopacket[20] = "Hello Photon #";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  //send the message
   // radio.send(RECEIVER, radiopacket, strlen(radiopacket));//target node Id, message as string or byte array, message length
    //Serial.println("OK, sent without retrying"); //Why send without retrying? If the RX is down for some reason, the TX will remain in a state of high power
    //which can drain your battery or overwhelm your power source.
    // Uncomment below and comment out above if you want to send with retry (which will look for an ACK message or resends)
     if (radio.sendWithRetry(RECEIVER, radiopacket, strlen(radiopacket))) //{ //target node Id, message as string or byte array, message length
     Serial.println("OK, sent with retry");
    //send message to Particle console if not using serial
    String TXMessage = "[NODE: " + String(NODEID) + "]  " + String(radiopacket) + " ";
    Particle.publish("Message transmitted",TXMessage,360,PRIVATE);
    radio.receiveDone(); //put radio in RX mode
    //print message received to serial
    Serial.println(" ");
    Serial.print('[');Serial.print(radio.SENDERID);Serial.print("] ");
    Serial.print((char*)radio.DATA);
    Serial.print("   [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
    String RXMessage = "[" + String(radio.SENDERID) + "]  " + String((char*)radio.DATA) + " [RSSI: " + String(radio.RSSI) + "]";
    Particle.publish("Message received",RXMessage,360,PRIVATE);
  delay(300);  //wait 2 seconds between transmits
} //end loop
The RX code will not fit in this post but it is the example code given in Particle Build for the library, RFM69-Particle. The github link to the examples is here;
https://github.com/bloukingfisher/RFM69-Particle/tree/master/firmware/examples
The serial print results for TX and RX are attached. Here is a link to my post in the Particle forum;
https://community.particle.io/t/how-to-make-rfm69-work-on-photon-solved-new-library-rfm69-particle/26497/69
which has run out of suggestions! Eventually I would like to use the Particle Electron to run a system of nodes. Any help would be appreciated as I have very little experience in these modules.
Thank you
