Hardware support => General topics => Topic started by: knute on May 13, 2021, 09:46:52 PM
Title: RFM69 Library and RaspberryPi?
Post by: knute on May 13, 2021, 09:46:52 PM
I want to use the RFM69 library with a RaspberryPi but don't really know where to start or if it has been done already.  Any clue as to what to do would be a great help.
Title: Re: RFM69 Library and RaspberryPi?
Post by: Felix on May 14, 2021, 09:12:10 AM
This library was designed for microcontrollers, so it won't work on linux computers.
I recommend using a compatible microcontroller board (specifically - the library was made to work with Moteino boards), which can then handle the radio communication with end nodes, and serial communication with a host computer such as RaspberryPi. That is much better than trying to make the Pi handle the radio communication directly.
Post by: knute on May 16, 2021, 10:04:06 AM
Thanks Felix.  I've been using Arduinos and the RFM69 library with excellent results.  Was just trying to figure out a way to get rid of one part.
