Pro mini + RFM69 receiving but not sending [solved: check IS_RFM69HW setting!!!]
Started by andre_x, June 08, 2016, 10:39:01 AM
andre_x
Hi guys,
I'm trying to use the RFM69 on an Arduino Pro Mini 3.3V. I'm checking if it's working with a Moteino. i see that the Pro Mini receives but doesn't send any data (the Moteino works both ways, I've tried it with a second Moteino).
I'm using the gateway and node code (already tried to inverting sender and receivers).
Before arriving at this point I've broken my head on my desktop working on other 2 RFM69 but with them I got nothing. Is it possible that I've broken them just soldering the cables?
Thanks,
Andrea
andre_x
I've just found out that puting the Pro Mini near the Moteino, the Moteino receives the data but the signal is under -80db (with antennas at about 5cm from each other).
What could the problem be?
Andrea
Incorrect settings, the HW setting is very important.
Noise, depending how you soldered this and how long the wires are you could be introducting noise but from what you describe i think its a software problem.
Is it worth breaking your head doing this rather than using a Moteino? (not looking for a sale but think of the energy, neural damage, and time spent to do it and then debug it).
andre_x
Hi Felix, it would be definitely easier to use a Moteino (I still have 3 or 4 laying around), but it the DIY that challenges me!!!
Here is the code of the Moteino:
// RFM69 library and sample code by Felix Rusu - http://LowPowerLab.com/contact
// Copyright Felix Rusu (2015)
#include <RFM69_ATC.h>//get it here: https://www.github.com/lowpowerlab/rfm69
#include <SPI.h>      //comes with Arduino IDE (www.arduino.cc)
#include <SPIFlash.h> //get it here: https://www.github.com/lowpowerlab/spiflash
#define NODEID        1    //unique for each node on same network
#define FREQUENCY     RF69_433MHZ
//#define IS_RFM69HW    //uncomment only for RFM69HW! Leave out if you have RFM69W!
#define ENABLE_ATC    //comment out this line to disable AUTO TRANSMISSION CONTROL
#define SERIAL_BAUD   57600
#ifdef __AVR_ATmega1284P__
#else
#endif
#ifdef ENABLE_ATC
  RFM69_ATC radio;
#else
  RFM69 radio;
#endif
bool promiscuousMode = false; //set to 'true' to sniff all packets on the same network
void setup() {
  Serial.begin(SERIAL_BAUD);
  delay(10);
#ifdef IS_RFM69HW
  radio.setHighPower(); //only for RFM69HW!
#endif
  radio.encrypt(ENCRYPTKEY);
  radio.promiscuous(promiscuousMode);
  char buff[50];
  sprintf(buff, "\nListening at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
  Serial.println(buff);
  if (flash.initialize())
    Serial.print("SPI Flash Init OK. Unique MAC = [");
    flash.readUniqueId();
    for (byte i=0;i<8;i++)
      Serial.print(flash.UNIQUEID[i], HEX);
      if (i!=8) Serial.print(':');
    Serial.println(']');
  else
    Serial.println("SPI Flash MEM not found (is chip soldered?)...");
#ifdef ENABLE_ATC
  Serial.println("RFM69_ATC Enabled (Auto Transmission Control)");
#endif
byte ackCount=0;
uint32_t packetCount = 0;
void loop() {
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input == 'r') //d=dump all register values
      radio.readAllRegs();
    if (input == 'E') //E=enable encryption
    if (input == 'e') //e=disable encryption
      radio.encrypt(null);
    if (input == 'p')
      promiscuousMode = !promiscuousMode;
      Serial.print("Promiscuous mode ");Serial.println(promiscuousMode ? "on" : "off");
    if (input == 'd') //d=dump flash area
      Serial.println("Flash content:");
      int counter = 0;
      while(counter<=256){
        Serial.print(flash.readByte(counter++), HEX);
        Serial.print('.');
      while(flash.busy());
      Serial.println();
    if (input == 'D')
      Serial.print("Deleting Flash chip ... ");
      flash.chipErase();
      Serial.println("DONE");
    if (input == 'i')
      Serial.print("DeviceID: ");
      word jedecid = flash.readDeviceId();
      Serial.println(jedecid, HEX);
  if (radio.receiveDone())
    Serial.print("#[");
    Serial.print(++packetCount);
    Serial.print(']');
    Serial.print('[');Serial.print(radio.SENDERID, DEC);Serial.print("] ");
    if (promiscuousMode)
      Serial.print("to [");Serial.print(radio.TARGETID, DEC);Serial.print("] ");
      Serial.print((char)radio.DATA[i]);
    Serial.print("   [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
    if (radio.ACKRequested())
      radio.sendACK();
      Serial.print(" - ACK sent.");
      if (ackCount++%3==0)
        Serial.print(" Pinging node ");
        Serial.print(theNodeID);
        Serial.print(" - ACK...");
        delay(3); //need this when sending right after reception .. ?
        if (radio.sendWithRetry(theNodeID, "ACK TEST", 8, 0))  // 0 = only 1 attempt, no retries
          Serial.print("ok!");
        else Serial.print("nothing");
    Serial.println();
    Blink(LED,3);
  pinMode(PIN, OUTPUT);
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
And here the code of the Pro Mini:
#include <SPI.h>
#define NODEID        2    //must be unique for each node on same network (range up to 254, 255 is used for broadcast)
#define NETWORKID     100  //the same on all nodes that talk to each other (range up to 255)
#define GATEWAYID     1
#else
#endif
int TRANSMITPERIOD = 150; //transmit a packet to gateway so often (in ms)
char payload[] = "123 ABCDEFGHIJKLMNOPQRSTUVWXYZ";
char buff[20];
byte sendSize=0;
boolean requestACK = false;
#ifdef ENABLE_ATC
  RFM69_ATC radio;
#else
  RFM69 radio;
#endif
void setup() {
#ifdef IS_RFM69HW
#endif
#ifdef ENABLE_ATC
  radio.enableAutoPower(-70);
#endif
  char buff[50];
  sprintf(buff, "\nTransmitting at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
    Serial.print("SPI Flash Init OK ... UniqueID (MAC): ");
      Serial.print(' ');
    Serial.println();
  else
#ifdef ENABLE_ATC
  Serial.println("RFM69_ATC Enabled (Auto Transmission Control)\n");
#endif
long lastPeriod = 0;
void loop() {
    if (input >= 48 && input <= 57) //[0,9]
      TRANSMITPERIOD = 100 * (input-48);
      if (TRANSMITPERIOD == 0) TRANSMITPERIOD = 1000;
      Serial.print("\nChanging delay to ");
      Serial.print(TRANSMITPERIOD);
      Serial.println("ms\n");
    if (input == 'r') //d=dump register values
      uint16_t counter = 0;
      Serial.print("0-256: ");
        Serial.print('.');
      Serial.println();
    if (input == 'i')
      radio.sendACK();
      Serial.print(" - ACK sent");
    Blink(LED,3);
    Serial.println();
  int currPeriod = millis()/TRANSMITPERIOD;
  if (currPeriod != lastPeriod)
    lastPeriod=currPeriod;
    if(sendSize==0)
      sprintf(buff, "FLASH_MEM_ID:0x%X", flash.readDeviceId());
      byte buffLen=strlen(buff);
      if (radio.sendWithRetry(GATEWAYID, buff, buffLen))
        Serial.print(" ok!");
      else Serial.print(" nothing...");
    else
      Serial.print("Sending[");
      Serial.print(sendSize);
      Serial.print("]: ");
      for(byte i = 0; i < sendSize; i++)
        Serial.print((char)payload[i]);
      if (radio.sendWithRetry(GATEWAYID, payload, sendSize))
    sendSize = (sendSize + 1) % 31;
    Serial.println();
    Blink(LED,3);
  delay(DELAY_MS);
Andrea
andre_x
Here the connections
You have a HW radio.
Why is your IS_RFM69HW setting commented out?
Hmmm, this has been mentioned about a thousand times on this site and forum, including in my post above.
john4444
Hi Andre_x,
Your wires and soldered connections look as if they may give you problems.
Be specially carefull to keep the ground connecton to the RFM short and wide.
A cm long ground connection can play havic with the transmissions.
John AE5HQ
andre_x
Quote from: Felix on June 08, 2016, 02:22:23 PM
My bad...  :-[
Actually I was supposed to have a RFM69W and not the HW version
By the way...thanks!
And awesome work!
Andrea
andre_x
andre_x
I supposed so, but searching I haven't found anything about removing it on a pro mini and I've found a lot of posts about the pro mini!
Thanks!!!
Quote from: andre_x on June 11, 2016, 03:25:38 AM
Thanks!!!
Sorry but this site is about supporting Moteino not pro mini.
