MoteinoMega GPS lowpower GPS shield ~ eagle files - comments please
Started by gregcope, September 23, 2017, 03:29:19 PM
gregcope
Hi All,
So long saga of me making a moteino GPS thing.
I decided to make prototype an Eagle design.  My first.  Comments / feedback please, as I intend to get this one made and try it out.
Files here;
https://github.com/gregcope/ABoatMon/tree/master/eagle
Background
- Uses COTS (adafruit) and Through hole parts as I cannot do SMD ...
- Has a high Ohm voltage divider to measure VCC in a low power way
- Has a p-channel logic level mofet (6020) to drive the GPS, but still allow the VBackup Battery circuit to be powered
- Has a Screw terminal to watch the logic of an exterior switch
Questions;
1. I think the MoteinoMega is upside down
2. Does the logic look right
3. Any obvious errors?
4. Any suggestions on what I can improve?
5. Any suggestions on PCB prototype manufacturer in the UK/EU (I only need a few!) ?
Ta.
gregcope
Hi All,
Some overnight thoughts;
0. I have accepted some ERS warnings (NETs that are not connected) and fix some other (missing values)
1. Fixed a layout issue due to wrong ALT GRID settings (doh!...read the instructions Greg)
2. Will add a Sparkfun DRC and run that
3. Check trace and Seperations are at least 10mil
4. Add a GRD pour
5. Upload a new commit.
gregcope
V0.2...
0. ERS and DRC (Sparkfun Rules) are both clean
1. Layout looks good (to me!)
2. One Copper pour - bottom - as GND
3. I think the trace and seperations are okay ... Advice please?
Will add a silkscreen with some info.  The board is intentionally left large as I am not sure on dimensions, and intend to add parts.
Not sure what to do bar choose a FAB.  Any advice?  I only want one or two.  Quick turn around preferred over saving any £££.  Does not need to be
Separation is OK. I would avoid right angle routing, not really a problem at a few Mhz but a good practice in general.
Your board seems to have a large farm land on the right size, it will really cost you.
You seem to be missing a via in the middle of the board where you route from TOP to BOTTOM, (where yellow X is).
I would add GND pour on TOP as well.
Some DRC errors will only show when the respective layers are visible, beware.
Oshpark if you want speed. PCBs.io is another, I am waiting for my first order from them so any thoughts on them are pending.
gregcope
Thanks Felix!
I discovered the cost today when I punched some numbers in for quotes... I will be making another version tonight!
gregcope
Lots of tweaks later v0.5 on github;
0. Much smaller (some stuff might not fit!)
1. Added a 12/24V Switched VCC from TomS (Thanks Tom)
2. Made some tracks 0.024 for either 5v @500mA or 12/24V
Thanks all.
gregcope
Have got to version 0.9!
- Learnt allot about Eagle
- Made a net class for power traces (0.24width) and updated all power nets
- Made it as small as I could
- Bar one Width error (on the top line) which I cannot resolve it passes OSHPark DRC and most of Sparkfun-standard (angles are an issue that I cannot get the Autorouter to sort out).
So think its ready;
Lastest here;
gregcope
Can I ask people review my P-channel mosfets (3 of)?
I also looked at reverse polarity protection - so have also added;
  • A polyfuse - any ideas?  This is to power a LIPO charger (0.5ma @5V) from a 12-24V regulated input
  • A schottky; 1N5819
  • Is the poly fuse supposed to be nearer VCC than the schottky?
Does that work?
If this is about schematic, I suggest posting a screenshot of your schematic, makes it easier to review.
gregcope
Ahh... attachment above seems to have worked.
Felix, does that help?
Greg,
Where does your 5V VCC go?  I only see a switched 12-24V going to a 5V PS (presumably) and 5V VCC going to two connector pins, but nowhere else.
How does your LiPo get charged?
gregcope
Will check but the 5v-vcc comes from the p-mosfet switched regulator.
The 5v goes to a USB plug on the gsm unit, which is also the Lipo charger.
gregcope
