Goto P-fets+fuses for input protection (12-24V)
Started by gregcope, December 02, 2018, 12:06:53 PM
gregcope
Does anyone have any goto parts for VCC input protection?  I am thinking poly fuses and P-fets.  Through holes best!  Also I need to protect from VCC being over 36V (regulator accepts upto 55V) for a 24V nominal circuit.  I only need 0.25A at 12V (600ma at 5v).
gregcope
#3
You can use a PFET for reverse polarity - drain to your battery, source to your load, gate to GND, easiest thing ever, almost no leakage, no voltage drop:
I would also read this excellent resource from Maxim on reverse protection: https://www.maximintegrated.com/en/app-notes/index.mvp/id/636
You can use a MOV for transient input protection, typically in higher voltage applications.
If you want close to 0 leakage, you can use a set of generic BJTs (ex 2N3904), as explained here.
For overcurrent, use a fuse, PTC etc.
I will also add this video with some extras and demo:
