The last time I actually used a thermistor was back in graduate school during the Carter administration when linearization was accomplished via suitable selection of a series or parallel resistor. State of the art has advanced somewhat since then. I would look for a library that uses the Steinhart-Hart equation if you can determine/calculate the coefficients for the thermistor you plan on using.
