Atmega328p-Au PWM Pin question
Started by JRoode35, October 21, 2014, 03:39:32 PM
JRoode35
I found this Atmega328p-AU Pin diagram online but I only see 5 PWM pins Labeled, I'm pretty sure that Pin 14 (D10) is the sixth PWM pin by referencing the picture of the Moteino and the Schematic. Could someone verify if this is correct? Please.
Thank You
Justin
You are correct, D10 is PWM as well.
