Hello all,
I'm using this library to enable communication between
AVR and
ESP32. It currently works as following:
NODE (can be multiple devices):
- AtMega328 wakes up every 60 minutes and reads sensors data
- AtMega328 sends data over RFM69HW and goes to sleep
GATWAY:
- ESP32 is in light sleep and RFM69HW is in Rx mode
- If data is received by RFM69, ESP32 will wake up by DIO0 pin and received data will be stored in ESP32
This works very reliably but I want to make gateway to be
solar powered. If RFM69 consumes 16mA all the time it will require pretty large solar panel and multiple 18650 batteries. My goal is to modify current project to work in
"Listen mode". This will greatly reduce power consumption.
In this approach everything should be working as described previously. Only difference is that node will send data by "
listenModeSendBurst" method and gateway will go to Listen Mode before ESP32 goes to sleep (by calling
listenModeStart).
Thanks to
@Felix for merging "ListenMode" branch to "master" branch.
I successfully tested this approach between two ATMEGA328 boards and it is working properly. But when I use ESP32 as gateway
it is not working as it should. When node sends data by "listenModeSendBurst" ESP32 wakes up correctly
but data is not received.
For testing purposes I'm using ListenMode_Master and ListenMode_Node sketches.
Any idea what can cause these problems?
